Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 09-04-2015, 05:33 PM
  #12391
hairymuffin's Avatar
Trader Rating: 105 (100%+)
Originally Posted by cnelson3
if you don't have the spacer between the inner and outer bearing, that will do it. If you have the spacer, a bearing could be bad or the hex on the wheel might be pressing on hub.
Ok,yea I don't have that spacer between the bearings(law253). I think that's why I keep blowing out the inner bearings. Thanks
hairymuffin is offline
Old 09-05-2015, 05:39 AM
  #12392
cnelson3's Avatar
Trader Rating: 66 (100%+)
We all learn that lesson the hard way. That spacer is there to put all the load of tightening the axles on the inner race of the bearing. Without that spacer, you are essentially pushing the inner race one way and the outer race the other. Binds up the balls
cnelson3 is offline
Old 09-05-2015, 04:13 PM
  #12393
oPAULo's Avatar
Went back to the 76 spur as recommended and dropped the timing to 10 on the motor. Zero SC timing. Thing got hot. Way hotter than when I was at 30 degrees timing. Dropped to a 20 pinion and still hot. I was at 84/22 so gearing is back close to where I was. I don't see how less motor timing would make it run hotter.
Something seems off here. Any pics I've seen of these motors have the letters lined up with the solder tabs. Mine are way off at 10 degrees and lined up at 30. I don't remember but did it have 30 out of the box? Guh..
I should be aligned to this notch in the case no? If my timing is actually way retarded that would make it hot I assume.
I actually turned some of my fastest laps today but that had more to do with finally making slicks work.
oPAULo is offline
Old 09-06-2015, 06:21 AM
  #12394
eper's Avatar
Trader Rating: 14 (100%+)
looks like the glue in the can let loose and something inside shifted. time to send it in
eper is offline
Old 09-06-2015, 09:30 AM
  #12395
oPAULo's Avatar
Thanks for the reply Eper!!
I didn't even notice it. Yup. The whole end of the can is loose and coming off. Lord knows how long I've been fighting this.
oPAULo is offline
Old 09-06-2015, 10:09 AM
  #12396
LiL CeeZ's Avatar
Trader Rating: 23 (100%+)
Just about ready, bodies are being painted and waiting on my power supply to get here and all systems a go! My 6 year old Son is so happy, bugs me everyday.
LiL CeeZ is offline
Old 09-06-2015, 10:19 AM
  #12397
Hi guys.
Does anybody know who makes gearcover for 3 gear gearbox?
uro76 is offline
Old 09-06-2015, 01:24 PM
  #12398
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
Originally Posted by uro76
Hi guys.
I just ordered a couple from a guy on FB that was linked or posted back on pg. 815 or something.
Teufel Racing is offline
Old 09-06-2015, 04:55 PM
  #12399
13Maschine's Avatar
I've just installed the RC Shox dual stage piston set in the rear of my RB6. it seems like the insert needs something to hold it in place. Does anyone have experience using these? Maybe you can post pics of your setup? I have the insert on top and the base on the bottom. I've watched the videos but it's a little hard to see.
13Maschine is offline
Old 09-06-2015, 04:57 PM
  #12400
Trader Rating: 50 (100%+)
Hi guys.
Chris Mielke on facebook
Jaz406 is offline
Old 09-06-2015, 05:22 PM
  #12401
Default 3 gear conversion for the rb6, rt6 and sc6
I have a facebook page and group on discussing my 3 gear conversion for the Kyosho line of cars.
go to facebook and search for "3 gear conversion for Kyosho"
Jaz406 is offline
Old 09-06-2015, 09:02 PM
  #12402
jag5508's Avatar
Trader Rating: 15 (100%+)
Looks good just ordered one .
jag5508 is offline
Old 09-08-2015, 08:19 AM
  #12403
13Maschine's Avatar
Let's hear some steering servo suggestions from the group. I'm leaning towards ProTek 170S or Futaba S9352HV. Probably the Futaba as it seems like it will be faster with lower voltage. I'm running this with my Futaba 4PX system. Thanks!
Old 09-08-2015, 09:48 AM
  #12404
Regional Moderator
RobsRacin's Avatar
Trader Rating: 13 (100%+)
Every single 10th scale car I have ever owned has had Spectrum 6040 put in it, I simply can not kill them whether its 2wd mod buggy, Short course, 4x4 mod buggy, stadium truck... never an issue
RobsRacin is offline
Old 09-08-2015, 10:52 AM
  #12405
RCmayor's Avatar
And to complete the conversion there will soon be this, in several colors. The end of the slipper adjustment will have a rubber over boot that slides on and keys to the groove.
RCmayor is offline
