Castle Creations Mamba Max Pro Sensored ESC
#91
Its been about 10 days with no sign of my castle link. I finally just went and bought one. Couldn't handle it anymore.
#93
Make sure you gear on the safe side to start and you'll be golden.
Ben
#94
Yes it will handle your battery. It will handle up to 6s lipo.
#96
So does the MM pro makes diference in modified with the 50º advance timing
#99
Our track is about 36 x 90.
I'm running 30 deg advance in cheat mode @ 7500 rpm and it was awesome.
FDR is 4.65
Motor temps stayed around 150f all night.
Plenty of rip and within inches of the Tekins on the back straight.
I need to play around with the throttle curve. It hit a little harsh on the low-mid throttle input. I like a little more butter on the low end. The harshness might have been upsetting the car enough to make me feel a little off all night. It's nice knowing there's plenty on tap.
I did have a strange hesitation on one of my starts. The car rolled gently a foot and then quit for about .5 second, then took off like a bat out of hell. It really brake checked the field and left me a sitting duck. The other three runs I stopped the car and launched it several times on the warmup laps and never had the issue again. Any one else encounter this?
Still very happy. Great value if you can live with the size.
Ben
#101
well we went on a street test
4600 mamba max pro system sc10 gear at 87/24 40c 5000 lipo
clocked at 60 mph
oh and did i mention when you hit lite poles stuff breaks
it dose power wheels it spins the tires and slips a locked sliper
clocked at 60 mph
#104
Is the 1s version being designed to fit in a 1/12th scale without grinding fins and stuff to clear the body?
#105
My only complaint for this ESC is that it does not brake hard like the LRP'S SPX. Having a hardtime braking late on hairpins. It might be my radio. my DX3r does not calibrate with my Mamba max pro. I belive Castle is working on it. Other than those mentioned above, I like everything about it.
