Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 06-28-2007, 03:40 PM
  #20461
PW
PW's Avatar
Originally Posted by protc3
no more posts at 3:00AM for adrian
Hope Adrian doesn't get another punch to the throat when the boss gets back into town
PW is offline
Old 06-28-2007, 03:51 PM
  #20462
protc3's Avatar
Trader Rating: 13 (100%+)
protc3 is offline
Old 06-28-2007, 03:56 PM
  #20463
theisgroup's Avatar
Default carpet chassis
Originally Posted by Sigearhead
Can you post some pics? Mine will be on it's way soon and I'd like to see what it looks like.
carpet chassis
Attached Thumbnails Schumacher Corner-hpim1023.jpg   Schumacher Corner-hpim1021.jpg
theisgroup is offline
Old 06-28-2007, 04:21 PM
  #20464
Skiddins's Avatar
Can someone please explain the different effect of rear toe at the hubs versus rear toe at the inner pivot pins.
Which is best?
A Combination?
Skiddins
Skiddins is offline
Old 06-28-2007, 04:50 PM
  #20465
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by yyhayyim
Its really not that big of a deal...unless you like to ram thru walls every lap, like Marcos
hey it takes alot of skill to hit every wall on every lap
Marcos.J is offline
Old 06-28-2007, 04:54 PM
  #20466
olhipster1's Avatar
Trader Rating: 102 (100%+)
before I go post up in the sale thread...
local track just closed...so selling off my MI3 (3 battery packs thru it)...with parts, 2.5 top/lower decks, lower shock towers and quite a few parts.
only tested on carpet.
If anyone is interested drop me a PM
olhipster1 is offline
Old 06-28-2007, 04:55 PM
  #20467
Sigearhead's Avatar
Trader Rating: 74 (100%+)
Which is best?
A Combination?
Skiddins
Using outboard rear toe allows the car to rotate better and carry more cornerspeed through the turns since there is less of an angle on the arms and the pins.
Sigearhead is offline
Old 06-28-2007, 05:13 PM
  #20468
hey guys mi2 ec question:
im running 2mm shims under my rear pivot blcoks plus the riser. how much can i run with out damaging the chassis?
finally jon kerr i did the changes u mentioned and added more rear droop and shortened the rear wheel base. what else can i do to get more mid-exit corner steering?
the car is amillion times better than before but im seeing how far i can push it. thanks for your help
aus jd 2703 is offline
Old 06-28-2007, 05:24 PM
  #20469
Super Moderator
Marcos.J's Avatar
having the front shocks inclined more than the rear should give you a little more mid-corner steering
Marcos.J is offline
  #20470
JayBee's Avatar
Trader Rating: 31 (100%+)
Skiddins-
You're rollin' a MI3 for goodness sake, clean up that wire'n!!!
JayBee is offline
Old 06-28-2007, 05:32 PM
  #20471
JayBee's Avatar
So you guys that have or have tested the 2.5mm chassis-
I have one and wondered if it's worth trying on med. to high-bite asphalt? I do want one of those 2.5mm kits too, where can I find 'em?
JayBee is offline
Old 06-28-2007, 06:04 PM
  #20472
AdrianM's Avatar
AdrianM is offline
Old 06-28-2007, 10:21 PM
  #20473
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You could also try kick up in the front. Do you have the pivot blocks all the way to the riser plate in the front? If not do that first. If so, add a .5mm shim under the forward front blocks. This should give more mid corner steering but it may take away some turn in.
Jon Kerr is offline
Old 06-28-2007, 10:30 PM
  #20474
JayBee's Avatar
Not everybody answer at once
JayBee is offline
Old 06-28-2007, 10:34 PM
  #20475
Jon Kerr's Avatar
Everyone's in bed except us.
Jon Kerr is offline
