Team CRC Xti 1/12th Scale!! >
Like Tree221Likes
    Hide Wikipost
Old 03-02-2021, 05:42 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team CRC Xti 1/12th Scale!!
Last edit by: tobamiester
Old 12-05-2012, 05:34 PM
  #751
Originally Posted by Wes Lawrence
Thank you avink007!
I flipped the esc around. We'll see how it goes. I'll post pics but honestly the wiring isn't up to par at all.
Fun kit to build! Went together very well and I've never built a 1/12 scale before. Running it tonight for the first time so we'll see.
First CRC that I have built, I have some great local CRC guys that I get to race with who gave me some great build advice so it went together well. I have to change my wires to smaller gauge though and a little shorter sensor wire. The car was great first time out, only about 0.1 seconds off the fast lap this last weekend, not too bad since I race against guys that have been top 10 at IIC and one has won Cleveland.
avink007 is offline
Old 12-06-2012, 01:15 AM
  #752
Default broken xti main chassis plate and rear pod plate
Team CRC my main chassis plate and rear pod plate was broken about a month or so ago. i posted on the tread about this and i also posted a few days ago about returning the both for replacement. i have since replace both pieces myself with the original xti chassis and pod plate. i have been looking for the old broken parts to send in for replacement for the newer version of the original xti chassis and rear pod plate. i seem to can't find them. because they was broken i probably threw them away. so what can i do to get the newer version of the original xti chassis?
bigtee is offline
Old 12-06-2012, 03:47 AM
  #753
is there any plan on selling the complete "altered ego" car
would make sense especially over here in europe
closs is offline
Old 12-06-2012, 09:45 PM
  #754
3D-Seth's Avatar
Trader Rating: 36 (100%+)
Can anyone post up an Orion r10 pro wired up?
Thanks!
Originally Posted by avink007
Here is my xti with an Orion r10 1-2s
Heres another.
I'm really really digging this car. About the 4th lap on the new car and I was already up to pace.
3D-Seth is offline
Old 12-07-2012, 01:21 PM
  #755
corally's Avatar
Bello ad you know KO 949 fit on Xti?
thanks
corally is offline
Old 12-07-2012, 01:44 PM
  #756
WIITA's Avatar
Trader Rating: 43 (100%+)
Your car looked great last weekend Vink! Its amazing what a simple chassis change did for you!!
WIITA is offline
Old 12-07-2012, 04:08 PM
  #757
Originally Posted by 3D-Seth
Heres another.
Damn, no "like" button on RC Tech. But I like! Thanks!
Team CRC is offline
Old 12-08-2012, 11:29 AM
  #758
For those who are looking for a setup sheet for the Xti, there is one on petit.
It is not as pretty as Frank and his crew can do but at least it is functional.
Arn0 is offline
Old 12-09-2012, 03:22 AM
  #759
tim fry's Avatar
I think this may have been asked already but will there be an Altered Ego complete kit coming?
tim fry is offline
Old 12-09-2012, 12:17 PM
  #760
3D-Seth's Avatar
Thanks! I really like this car, raced it the first time last night at our club race. Qualified 2nd (0.01 seconds behind ) and won the main. This car rocks!
3D-Seth is offline
Old 12-09-2012, 01:44 PM
  #761
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
I'd like to reduce the bump toe-in on my Xti. I have the outer ball studs shimmed up and am using an Airtronics 94761 with the Kimbrough 114 servo saver with the inner ball studs mounted in the middle holes. The manual has you add a shim between the servo and the chassis. Is there a purpose for these shims I am missing?
andrewdoherty is offline
Old 12-09-2012, 08:01 PM
  #762
Without the shims under the Sanwa, the servo saver hangs below the plane of the chassis.
Team CRC is offline
Old 12-09-2012, 08:15 PM
  #763
Just what I was looking for. Thanks Frank.
Old 12-10-2012, 04:34 AM
  #764
Skiddins's Avatar
Does anyone know what rating the kit damper tube oil is?
Skiddins is offline
Old 12-10-2012, 06:50 AM
  #765
b_recliner's Avatar
Trader Rating: 22 (100%+)
Heres another.
good job on the layout. that's one of the cleaner installs i've seen on the xti
b_recliner is offline
