Like Tree7Likes
Painting a body A to Z
Old 12-03-2011, 07:31 AM
  #46
samshirley00's Avatar
Thanks, never been good at bodyshells.
Never thought of the sharpie around where to cut.....
samshirley00 is offline
Old 12-22-2011, 05:04 AM
  #47
Any tips for painting lexan body in 30 - 50 degrees weather? I'm going to use a spray can.
coconut is offline
Old 12-22-2011, 05:10 AM
  #48
R/C Lidz's Avatar
Trader Rating: 59 (100%+)
heat up the cans in a water bath and use light coats so they can dry quicker. Use a hair dryer to dry them- both sides of the body
R/C Lidz is offline
Old 12-22-2011, 07:51 AM
  #49
Thank you
coconut is offline
Old 01-02-2012, 06:01 PM
  #50
Default Protect the paint job internally
I had a guy paint my Losi 4x4 shell in my color scheme. However, once on the car, things like clay spray from tires, and other things started to scratch and wear the paint so now the "outside" of the shell looks bad.
One suggestion was putting duct tape at certain areas inside the shell. Another is applying Shoe Goo, which forms a pretty hard protective surface, but I don't know how long it lasts.
Also, applied decals to the outside are wearing, too. How do you protect the outside? Some kind of a clear spray without messing up the clear windows?
What's the best way to protect?
TakeAim
TakeAim is offline
Old 01-02-2012, 06:04 PM
  #51
3D-Seth's Avatar
Trader Rating: 36 (100%+)
Not sure if its something just with my computer settings or not, but I can't see any of the photos in the original posts. Just little red x's.
I'm a visual person so seeing these would help a lot!
Thanks!
Seth
3D-Seth is offline
Old 01-02-2012, 06:14 PM
  #52
Bfutura15's Avatar
Thanks!
Seth
It is probably because the post is 2 yrs old and the original photos are no longer hosted. I cannot see them either.
Bfutura15 is offline
Old 01-08-2012, 03:25 PM
  #53
Dang all the pictures are down. Does anyone know what masking tape works? Got some painter's tape but that stuff is kinda expensive. Don't mind using it if masking tape doesn't work. Like masking because you can actually kinda see through it.
skipnay is offline
Old 01-16-2012, 07:43 PM
  #54
Try tamiya masking tape. They're really good
s10096898 is offline
Old 02-13-2012, 09:36 PM
  #55
keith09's Avatar
Alright I have a question about pinstriping. I am working on my second liquid paint mask body. I want to put a 1/4 pinstripe around the inside of the window. I have seen this on alot of bodies and was wanting to know the best way to go about doing this. My last one came out bad. Please help.
keith09 is offline
Old 04-19-2012, 08:51 AM
  #56
Yea, me too, please help
b.wihardja is offline
Old 04-19-2012, 09:04 AM
  #57
Colors_By_Dave's Avatar
Trader Rating: 84 (100%+)
Two ways (there are many):
1. Use the factory masks for the windows, but before you install them in the shell, carefully cut a second line inside the edge, to the width you want. Use de-tacked masking tape, or transfer tape, to put the mask into the shell.
2. Use liquid masking film to mask the windows/body, then carefully cut both lines inside the body.
Other ways....
Use narrow tape to layout the pins.
Mask with tape, cut two lines for the pins.
Vinyl cutter: make custom vinyl masks with trim lines for pins.
Paint them with a brush (not suggested)
Paint them with a Sharpie (not suggested)
Paint them with a paint pen (not suggested)
Freehand them with your airbrush (Really not suggested)
There might be other ways also.
Colors_By_Dave is offline
Old 05-22-2012, 06:43 PM
  #58
JoePit's Avatar
Trader Rating: 15 (100%+)
Tomorrow I will be starting my 1st paint job using liquid mask. Is there still a need to use the supplied window masks when using liquid mask, or shoot the whole body and cut the windows and such out later?
JoePit is offline
Old 05-22-2012, 07:42 PM
  #59
1967rs's Avatar
Trader Rating: 56 (100%+)
I dont use the supplied window masks any more but I did when I first starting to paint bodies. I found it took me more time to get the masks on straight then it takes me to just free hand cut them. It all depends on how steady you are with the knife, if you are unsure use them.
1967rs is offline
Old 05-23-2012, 01:20 PM
  #60
Hey y'all Im getting ready to airbrush my 1st body then I saw the new car action about the spray boom paint and I saw where he used a scuff pad on the body. Do u guys do anything like this or should I just go ahead and just spray with the airbrush?
special_k is offline
