Spec-R R1
#3736
I have the 1.1 sway bar up front and rear. If I was to lift up the chassis and compress one side, shouldnt the other side raise even just a little bit? I thought that was the purpose of these to prevent traction roll. (Which btw I'm not experiencing. Just curious to this) Its the same with the fronts and the rear. I dont see anything binding. I've even loosed up the sway bar holder with the set screws. Still nothing.
#3737
You wouldn't really see it but you might feel it. its hard to feel the difference a rollbar makes with the entire suspension assembled until you get into the 1.4/1.5 but the effect of the cars weight transfer i still there. if you remove the shocks, remove the chub/steering bocks and you are left with just arms, both side should move the other with any of the swaybars.
#3738
Thx Valk
#3739
Was gonna rebuild my rear diff but turns out I don't have any 3000 wt oil that I wanted to try. Lowest I have is 10,000. Is that too thick for the rear?
