Tamiya F104 Pro!
#4803
Pm me if you are interested
#4804
Thanks for the reply
On what body do you use the decals?
regards Roy
regards Roy
Decal island did the W01 decals, the sheet also includes the virgin livery, you can get them through Ddrive sports in japan. I have them for sale too, but I'm not sure what would would be a better deal shipping wise for you, for me to ship from the states, or for them from japan
#4809
PM if you are interested
#4810
You mean this one?
http://www.rctech.net/forum/8802908-post4746.html
regards Roy
regards Roy
A couple of pages back there are pictures of a McLaren all built up and ready to go. It is essentially a pro black edition without the carbon chassis. It is built with all stainless screws, and although it is shown with a McLaren body, I could do a Mercedes W01 for it . $450USD Will get it shipped to you or anyone else
#4812
Getting closer! i have added 12th scale open to the roster and the date has changed too.
#4813
The best body for the W01 stickers would be the Tech Racing F125 MG10 body, considering it is the early W01 complete with blade roll over hoop. The problem is finding anywhere that actually sells the body separately.
#4815
I have a similar setup. Works good on carpet:
Front: (everything kit set except)
Toe: 2.0 deg out
Spring - black (hard)
Ride Height - 3.5mm
Rear: (everything kit set except)
T-plate Tension - 1xO-ring & very loose
T-plate Type - High Traction plate
Friction Plate Lube - none
Friction Plate - F104Pro stock
Friction Plate Tension - 3 mm
Shock Oil - tamiya red #200 shock oil
Shock Spring - F104Pro stock
Ride Height - 4mm
Axle - carbon
Diff Grease - associated stealth (black writing on tube)
Diff Tension - as loose as possible without slipping. (Critical setting)
General
Esc - Speed Passion Club Race
Servo - Sanwa SDX-801
Motor - GM 13.5T
Battery - LRP 4000 LiPo
Tires - Tamiya foam (front hard, rear f103 hbr soft)
Ambient - 22 deg Celsius
Track - carpet, technical.
