Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 03-23-2011, 01:42 PM
  #4786
Trader Rating: 47 (100%+)
Originally Posted by 2-Bad
Once u try Black, u never go back, hehehehe
transplantlife is offline
Old 03-24-2011, 10:21 AM
  #4787
How are you guys liking your EXOTEK chassis so far thinking on getting one.
Old 03-24-2011, 11:38 AM
  #4788
Trader Rating: 61 (94%+)
Cant go wrong with geting the exotek upgrade.. i love mine. Lots of rear bite. lots of steering. very fast car. MikeR is a great guy. Im about to win the winter series down here in fl with mine. It turns faster lap times than the vta class down here. Im running 21.5 vta is running 17.5.
tcb22185 is offline
Old 03-24-2011, 11:58 AM
  #4789
Thanks for the info i jus pulled the trigger on a BLACK EDITION last night and was going to order this chassis today. Thanks again
Andrew
Old 03-24-2011, 07:47 PM
  #4790
gsxr0311's Avatar
Trader Rating: 19 (100%+)
i second that. i love mines also. im waiting for the outdoor season to start here. we had a winter points race and i took 2nd with the exotek. my car felt great, way better than the regular 104.
anybody have any experience with the pit shmiz on a prepared track compared to the tamiyas?
gsxr0311 is offline
Old 03-24-2011, 07:57 PM
  #4791
Thanks guys!
What are your set ups for carpet and tarmac? Like a baseline set up.
Old 03-26-2011, 05:49 PM
  #4792
Old 03-26-2011, 10:29 PM
  #4793
im running on very bumpy asphalt track silver front springs. ride s2 fronts 15wt oil in center shock and side dampn running tamiya soft rears. .5 toe in. 0deg camber. put im going to play wit that a lil bit more. I just won the 1st points series with the car. best five out of 6 won all six. very good car.
tcb22185 is offline
Old 03-27-2011, 02:40 AM
  #4794
2-Bad's Avatar
Trader Rating: 24 (100%+)
Here's is my current setup which may assist you....
Front: (everything kit set except)
Toe - 0.5 deg out
Droop - 0.5mm
Spindle Shaft - thick diff grease
Spring - black (hard)
Ride Height - 6.5mm
Steering Throw - maximum
Rear: (everything kit set except)
Droop - 2.0mm (5mm spacer in shock)
T-plate Tension - 1xO-ring & very loose
T-plate Type - High Traction plate
Friction Plate Lube - 15wt shock oil
Friction Plate - teflon covered
Friction Plate Tension - 2mm
Shock Oil - 20wt
Shock Spring - HPI copper (8lb)
Ride Height - 6.5mm
Axle - steel
Diff Grease - associated stealth (black writing on tube)
Diff Tension - as loose as possible without slipping. (Critical setting)
General
Esc - Tekin RS
Servo - Airtonics 94851 (12th scale micro) kicked up at angle to reduce bumpsteer
Motor - Speed Passion 21.5
Battery - IP4200 LiPo
Tires - Tamiya kit (frt & rr mediums I think they are)
Traction - FXII full frt & rr baked 60deg C, for 15min before race.
Ambient - 27 deg max
Track - asphalt, technical.
The tire selection & balance is the most important, the next is the diff tension. It's a pain to adjust as it's got to be done on the track, but once set correctly you will gain max grip from ur rear tires.
Hope this helps....
2-Bad is offline
Old 03-27-2011, 04:06 PM
  #4795
Default foam tire questions
This may sound kinda silly but I picked up the front foams yesterday, rears are still on the way, and I dry fitted them on the rims just for kicks, all tamiya stuff. The tires seem a bit small for the rims, maybe 1/4 or so not wide enough? Do they need to be stretched out, all the part numbers were right, and the tape that comes with the tires has a white wax paper backing thats easy to peel back but does the other side have a clear plastic backing?
I'm assuming its two sided tape but I cant seem to see how to get the other side off or even see it. Like I said, seems silly to ask but maybe you guys CA them on? Wanted to ask before I make a mess.
JoeD. is offline
Old 03-27-2011, 07:00 PM
  #4796
What are u guys doing to keep the top a-arm from bending in the middle?? any one seen the 3racing ones?
tcb22185 is offline
Old 03-27-2011, 07:44 PM
  #4797
robk's Avatar
Trader Rating: 22 (100%+)
Don't crash?
robk is offline
Old 03-27-2011, 07:55 PM
  #4798
robk's Avatar
http://rcf1blog.blogspot.com/2011/01/tire-mounting.html
The tires are usually a little narrow.
robk is offline
Old 03-28-2011, 06:19 AM
  #4799
Default blog and info
Oh man Rob, I love all the info on your blog, I will be spending hours on it now. Thank you so much for sharing your experience.
I see your front foams dont quite make it to the edge on the inside if you make it flush to the outside. You would think someone would have caught that by now LOL!!
I know what you mean by not getting the tire glued in the middle and truing them later and getting a gap in the middle. That happenned to a brand new set of Jayco 12scale tires a few months ago, big waste of $15, and what the heck do you do with one good tire? Will have to glue my rear tires on the morning of race day, hope they will have enough time to set up before racing.
Hope I wont suck too badly, will also be running my mini and GT2 car ( TA05 ) in a TCS race this sat near London Ont. thanks again JoeD.
JoeD. is offline
Old 03-28-2011, 06:36 AM
  #4800
Questions?? tamiya tt01
btw what is the tamiya tt01 quick change right hand motor mount for (whats the difference from the usual motor mount) what degree for the hub carrier should i use if i want speed (performance)? please reply
briankho is offline
