Murnan Modified Motors
#2896
#2899
Cheers
#2900
my bad, I ment xl3. I purchased it from someone on the forums and the case is unusually tight. The back plate is even a challenge to remove which from what I have seen is unusual in the 10 or so high end nitro engines I have had. I suspect they flipped the car and it took a good hit tweaking the block. So now the question is is an XXL3 case compatible with the XL3?
Cheers
Cheers
#2901
#2903
#2906
#2907
Which engine are you running, where is the head clearance?
#2910
