TC3 Forum
#2221
#2223
Regional Moderator
For those that use the Front-one ways, do you recommend them?
#2225
Regional Moderator
thanks big al. One of my buddies sold his TC3 but kept some hop ups and this was one of them. I put it in my car to see how the car would handle. I read down below where some brakes should be taken off, I agree with that.
I haven't tried that Rear mount up front, is that the norm?
Thanks.
Thanks.
#2226
The rear tower up front allows more aggressive shock and camber positions, giving a lot more steering - this is needed if you run a locked front diff (locked diff takes away steering. . .)
It isn't the norm, but is becoming more and more accepted. TonyP has been running it for a while (since the Reedy Race preparations) and loves it. . .he actually thinks it's more consistent than using a one-way.
I'm running a one-way and am not all that sure I like it. I am real consistent when I am on my own and don't have to adjust my lines to get by people or to block people. . .if I have to do that I have some problems. The one-way likes a single line, pretty much. yeah, it's something of an exageration, but still, the one-way line is much less tolerant than a dual diff line.
I am going to move to the locked front setup this week. . .
#2227
I'd have to agree with yo boomer. On my previous tc's (mr4,axis2) the one way just never liked dodging traffic. They just seem to like flowing,open turns. I think you're really gonna like the rear tower up front. I tried it from the get go last weekend and never put the old tower back on. It was nice to pass on the inside while still accelerating!!
#2228
So when you say you have a locked front diff, that means that you have tightened the bolt so that the spring is fully compressed eg a solid front axle basically?
I have found that the rear shock tower on the front makes little difference with a std diff(not locked) at the front. It is a good idea though, because then you only need spares of rear shock towers!!
CYA
CYA
#2229
Has anyone tried the rear on front shock tower with the center one way?
#2230
Boomer: as i suspected, the previous owner of my fttc3 dint shim the gear cases properly. he dint have the shim on the long end of the front & rear diffs plus he had one too many in the front input shaft. i looked up josh cyrul's advise in tech talk on shimming the gear cases and i think i did a pretty good job. the gears feel really free now and spin very smoothly. hopefully this solves the noisy drivetrian issue. will find out this weekend when i put the car on the track again. thanks!
RandyB: the MF option rear hubs for the xxxs come only in 0 deg. the xxxs comes with bulit in toe-in in the rear of 2 deg and trinity probably dint feel the need to make optional rear hubs (only God knows why....). ive got a xxxs myself and when i wanna play about with the rear toe, i have to use the composite/graphite hubs since they come in varying degrees.
#2232
Regional Moderator
Boomer - let us know how the locked front diff works out. When you say locked you mean no diff action whatsoever correct, like a gear diff
#2233
Roborat, try a dab of losi white grease on the gears...
You will notice a big differents , most of the gear noise sould dissappear.....try some on the dog & drive shaft pins as well...
#2235
yes
