Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 10-01-2016, 10:24 AM
  #2476
Trader Rating: 166 (100%+)
jpcopeland1 is offline
Old 10-07-2016, 02:14 AM
  #2477
Has anyone else had trouble with the servo moving from even the slightest of knocks? Both me and a friend are having this issue which we never had with the original Yokomo yz2.
Cheers
Mi4cxl is offline
Old 10-09-2016, 08:07 AM
  #2478
Trader Rating: 15 (100%+)
Edit nm. Found my answer.
YMMV is offline
Old 10-09-2016, 10:41 PM
  #2479
Originally Posted by jpcopeland1
Thats too bad cause not only are the prices now not worth the cost to maintain the buggy, but they are also slow in getting new upgraded pieces that come out. I got sick of waiting for the longer rear arms and needed suspension mounts for the YZ-4 so I got them from Europe the day of release, Amain was almost a full month later.
Prices are comparable to everyone else. The alum hopup parts are pricey, but none are needed on the DT.
robbie_gtc is offline
Old 10-10-2016, 03:41 PM
  #2480
MOmo's Avatar
Cheers
I had trouble with my Bmax CONSTANTLY. the screw in the servo horn would loosen or back out. I have V1 YZ-2 and so far, not too many problems with the horn or steering movement
MOmo
MOmo is offline
Old 10-16-2016, 03:46 AM
  #2481
YellowClip's Avatar
1. Does the heavier front lower suspension mounts weight show its overall weight or how much it's heavier than the original piece?
2. How do you achieve 20+ mm of front travel with the shock in the middle hole on arm without outscrewing the adjuster on the body?
YellowClip is offline
Old 11-01-2016, 04:23 AM
  #2482
ironsylvain's Avatar
Originally Posted by PENN01
Just had my first run with my new dt edition and i must say it feels that good to drive already but does anyone have any tips for even more tuning for low bite outdoor track ?
Please try this one...
ironsylvain is offline
Old 11-02-2016, 11:59 AM
  #2483
Trader Rating: 165 (100%+)
Originally Posted by GSM Storm
This is a spring chart we made using a G Force spring tester, the rates may not be 100% correct but comparing one brand of spring against the other is.
Regards
Gary
Do you have any comparisons with the Yokomo Yatabe springs?
Chris Gierse is offline
Old 11-02-2016, 04:57 PM
  #2484
Trader Rating: 11 (100%+)
Does the Exotek 24g front/rear brass weight fit on the CA/DT
rippen is offline
Old 11-05-2016, 01:33 PM
  #2485
What is everyone liking for the yz2 ca for diff fluid tight high grip carpet?
turtle189 is offline
Old 11-05-2016, 07:00 PM
  #2486
Don't know about the ca. It doesn't fit the dt. Hard to explain but basically it interferes with the motor plate.
71WOK is offline
Old 11-05-2016, 09:04 PM
  #2487
MarkA's Avatar
Trader Rating: 21 (100%+)
3or5k depending on just how high your high grip is and the rest of your setup.
MarkA is offline
Old 11-06-2016, 05:16 AM
  #2488
Thanks for the info. I went with the steel front/rear C mount.
rippen is offline
Old 11-15-2016, 07:33 AM
  #2489
YellowClip's Avatar
What servo arms do you use on your buggies?
I have the RJX FS-0521HV servo and have used the Robitronic lightweight aluminium servo horn. At the last race, my fellow competitor pointed out, that as the servo arm doesn't have any offset, the nut used to hold the rod ball end on to the arm hits the servo case and limits steering end point. The original Yokomo horn puts the servo link at a such big angle, which in my opinion makes the steering uneffective.
Old 11-15-2016, 09:53 AM
  #2490
I am going to try a TLR aluminum horn for the 22. It seems to have a similar off set tot the OEM Yokomo plastic horn. I had to drill and tap it for the 3mm ball stud however. I also ordered a 20mm Kyosho turnbuckle from AMain I plan to use between the ball cups. The manual says to screw the cups together but I don't like the angle of the servo like that, I like th servo to point straight up for straight ahead wheels. I plan to add 5mm of a gap with the new turnbuckle and the cups.
HeavyD99 is offline
