1/10 R/C F1's...Pics, Discussions, Whatever...
My solution wasn't as elegant, but easier. Mill a small channel out of the underside of the bulkhead and then drill a hole up from the bottom so that a small piece of carbon fiber/aluminum/whatever could be sandwiched between the chassis and the bulkhead and held in place with the screw. That's something that most anyone could do, even before Mike can get the molds changed.
Aaron
Im just thinking about how simple the F103 is. No side springs, one shock and some o-rings. Simple front suspension.
I could kind of agree with your point, but F1 is just evolving, like 1/12 has. Were you referencing the FGX or the new exotek front end? Innovation is better than stagnation, IMHO.
I'm really surprised it took so long to get the dual dampers configured like a 1/12 scale to finally show up in F1 (ala exotek and the new Yokomo).
There may be a lot of innovative designs out there for pan cars, but realistically have any really made that much difference? Tyres are really the most important thing + weight distribution and wheel base.
Gorgeous, but I came back to my senses when I realized it would be $150 ($85 for upper arms, $65 for IFS). That's nearly the cost of my SP-1, lol.
I hope it's good, but not good enough to be a game changer if you catch my drift
I ordered two.
What tires do I need?
This winter season on a large carpet track with medium grip.
and for the summer asfalt (tarmac) big high-speed track low grip.
Pit shimitsu
Ride
GRP
Tamiya
Pit shimitsu
Ride
GRP
Tamiya
The upper arm sets are less than $39 at most places.
Carpet: Pit 0571 front and 0572 Rear
Asphalt: Pit 0571 on the front, Ride R1 on the rear
As for the Ride R1's, I have used both the preglued set of tires/wheels and bought the tires and wheels separately to glue them myself. Either way is fine, but the glue job on the preglued sets is hit and miss. Either way, I have found that I need to re-glue the sidewalls as they seems to crack easily, but they were still the best for my local track and conditions.
Any idea on what size and where one might find replacement screws and nuts for the tamiya rear wing? Those small ones that hold the sides to the center.
Also any good replacements for the top of the servo saver? I lost mine when I was looking for a screw to hold it down...
Use Associated 4674, they have a hex head and work much better, I use them in all my wings
