Hot Bodies TCXX
#286
The original TCX cups were the short ones, the kit came with 46mm drive shafts.
There was a shortage of 46mm shafts and the 44mm ones were too short to fit the spool cups.
In the end HB brought out the long cups (68769) so people could use 44mm shafts in the front.
The upshot is that the long cup works with both length shafts and the short cup has to be used with 46mm shafts.
If you mean why can't you use the TCXX cup, it's because the drive pin is a different diameter.
#287
Does the Spec-R's HB-TCX spur gear adapter and pulley set fit the new TCXX?
thanks guys
thanks guys
#288
The mounts are the same, and they are spaced the same, so I'd have to assume that they will fit both cars.
#289
#290
Thanks AGNO for the info!
I tried to use the Spec R's C.V. Universal Swing Shaft Version 2(For Tamiya TRF416/417) 44mm thinking it would fit but knuckle hits the C Hub when you turn it left or right, would getting the Spec R's C.V. Universal Swing Shaft (For Hot Bodies TCX)Version 2 46mm fix the problem?
thanks guys for your time..
#291
#295
Thanks again AGNO!
I ordered the #61087 so the Spec R's C.V. Universal Swing Shaft (For Hot Bodies TCX)Version 2 46mm should be right to use now!
