Schumacher Corner
Originally Posted by wyd
Anyone know of a good place to get a voltage regulator for a lipo receiver pack? Lipo is 7.4 volts so I need a 6 volt regulator? Never messed with this before and this is my first time so if anyone has any experiance in this and can help let me know.
Brian
Brian
My Mi2EC was awesome yesterday. Qualified 4th and finished 2nd. We had a handful of top drivers from our area show up to our indoor asphalt track. I had a couple guys come up to and ask what I was driving. They where shock that the Schuie was that good. One qualifier my fast lap was 12.25 and my ave. lap was 12.399. What a day.
I think the Mi2EC is working this good because it knows it is soon getting replaced.
Trader Rating: 51 (100%+)
Originally Posted by adamge
Marcos linked to low voltage cutoffs. You want a voltage regulator. Here's some good ones:
http://www.rctoys.com/rc-products-ca...EGULATORS.html
They are available as straight input-->6.0V, and also with a switch.
Originally Posted by dawgmeat
Tx or Rx
Originally Posted by Mopar
One complaint, when you get the set-up close, it's hard not to over drive corners. Randy, Burt, and I all have slightly differant S/U's and all three seem to work good. The track had no Sorex on the wall so I ran old well run RP30's and the car ran great untill 5th lap in the main when they went away. Wanted Randy to try my car, but by then there was no point. One more week to practice before Reedy. This car is just so fun. BTW Randy's car looked 'preddy' dialed.
I didnt have a problem overdriving the corners, mine still had a good amount of steering. Try running only .5mm shims under the front hinge pin mounts, and on the rear 3mm on the back block and 2mm on the front block. Also I changed the shocks, drilled the pistons out to #56 and ran 45wt oil in the front, 40wt in the rear, with 1 red O-Ring under the bladder on all 4. 17lb front and 14lb rear springs.
Yeah, was already thinking 5wt heavier front oil or .5mm kick-up in the front. I thought I noticed that you had your shocks one hole out on the tower or am I wrong on that. I did notice you had blue(tamiya?) front springs, was going to ask about that. I'm sure we'll all get there one way or the other.
lol I was trying not to say Tamiya springs, but yes they were.
I am running PW's setup on everything but what I listed as the changes there, .5 less toe-in in the rear, and 1mm sweep on the front arms.
Trader Rating: 102 (100%+)
just a quick question
just wanted to throw out a quick question.
will shu come out with and carpet version of this car?
or release a thicker top deck/chassis set?
it's crunch time and I'm looking for a replacement car.
Yeah I need to place an order today or tommorrow. Need for early next week. Thanks for the help.
dawg, your link is much better. This unit here is much smaller than the ones I linked, and much cheaper, too.
http://nexusracing.net/product_info....b42bb16f19e083
-Adam
-Adam
Nexus is the shiznit if you order today you'll have Wed.
-Adam
-Adam
