Schumacher Corner
Regional Moderator
Originally Posted by yyhayyim
Had trouble with the center pulley assembly- on the manual it says put the caps on one way, with the indentation towards the outside...tried this but it doesnt fit- does this have to be reamed if needed, or can I just put them with the lip towards the outside and the indentation towards the pulley/inside?
all Orion 4800 Lipo users- its possible to run the 4800's on the Mi3. All that needs to be done is a minor mod to the top left corner of the pack. Just dremmel off about 2mm at an angle from that corner about 1/2 way down the pack. This creates enough clearence for the purple steering block on the steering linkage and all is good. Its easy to do and barely noticable---but best of all, no need to get rid of the 4800 or trade for the 3200...
Originally Posted by JayBee
Does anyone know what springs come with the Pro-touring set?
Finally I'm done
I would have been dome earlier but I had to paint my son room and took
him to watch sherk3
I came up with a idea for the antenna mount, I'll let pic speak for itself
him to watch sherk3
Regional Moderator
dawg: GREAT looking car!!! Very clean look in the electronics area.
The Core 5000mah LiPo is a new product we are testing. It will sell for the same price as the Orion 4800. The Core 5000 is a 2s1p pack (2 5000 cell in series. The Orion is 2 pairs of 2400 cells in parallel then connected in series to make a 2s2p 4800 battery. The Core 5000 will have a lower internal resistance and better curretn delivery capacity.
We should have them in about 4 weeks.
Trader Rating: 51 (100%+)
Here is my MI3.
Super Moderator
Originally Posted by wyd
Here is my MI3.
wait until you see mine
Originally Posted by AdrianM
I ran my Mi3 for the firwst time at B&B hobbies in Hudson FL. I used PW's FSEARA #3 setup and it was dialed. I added .5mm shims in the rear for a little more toe and it was perfect. It had loads of steering and corner speed. At the end of the day I was at 85% dual rate where I was normally at 95-100% eith my Mi2EC.
I also ran the new Core Racing 5000 LiPo pack. I was just as fast as anyone there and just kept repeaking the pack for every run. FYI, I used only 2200mah in a 5 min 19T run.
your car did run awesome today bro.i really liked how the car felt.
Here is my MI3.
Originally Posted by dawgmeat
Holy Sh!t thats tight
If I only ran pan cars I would have tons of room on the 1/10th oval cars.
Everyones MI3's look great. Just went over some final adjustments on where I want to start. Everything has been gone over but will be double and triple checked on MOn and Tues to make sure I'm 100% ready for Wed practice.
Still might have to run a lipo receiver pack and regulator. I have the room but will have to really take my time with the wiring then.
it's time to remove Mi3 (soon) from your avatar
I ran an LRP Sphere Comp 07' and used the LiPo battery mode. This cuts off the power to the motor when you hit the minimum safe voltage (6v).
14lb
16lb
18lb
20lb
23lb
27lb
