Tekno RC EB48.3 Thread
#631
This depends on which ESC and radio you are running?
These are all servos I have ran with great results and relatively low price points. Savox seems to have brown out issues with Spectrum and low voltage esc's(6v internal BEC).
Hitec 7955TG
Protek 150T
Protek 170T chad bradley edition
Highest 2100
Savox 2273sg
Hitec 7955TG
Protek 150T
Highest 2100
Savox 2273sg
#632
been running the old faithful hitec 7955 for quite a while. Decided to try out the Savox 1270HV on my SCT410.3 and have been impressed. If old faithful finally bites the dust i'll give the Savox a try in buggy.
#633
What temp is your motor after the run? I'm running a SMC 1900 kv and HW XR8 (4 degrees of timing) with a 17 tooth pinion and it gets a little warm. Motor comes off track around 170 after a 12 minute run. I feel like a 20 tooth would cook the motor. You're not too hot?
Thanks.
Thanks.
I can't speak for all the servos on the market, but what I've tried. Protek servos all the way. I have a 170s on 7.4 in my buggy and the 150's as my backup. You buy your servo on specs, find the one that falls in the range you want. I stuck with protek because its butter smooth. Smoothest servo I've ever used, NOT the cheapest. Buy a good servo and it only hurts once.
#634
Hitec 7955TG
Protek 150T
Highest 2100
Savox 2273sg
Hitec 7955TG
Protek 150T
Highest 2100
Savox 2273sg
The highest servos. I'm kinda thinking they are rebadged proteks.....EXCEPT, you can get laser engraving on them. Servo with your name on it....thats hard to beat
#635
Im 160-170 all day long. When i need it i throw a 21 at it. T8 handles the heat the best, I think. Off all the motors I've tried, the tekins are the coolest. Now the SMC motor is a good motor as long as you can get your temps under control. When they first came out a couple of us bought them. It was a rocket, it also picked up the name "heat monster" because she was hot. I don't run any timing, you don't really need it. You also may be under geared. You should look at that. Running that motor wide open more then you think. Running that thing at red line makes a lot of heat because I don't think I've ever ran a pinion that small on my tekno's. Hope this helps
#636
Regarding gearing of 1900kv motors. Start 18t, I've found it good almost everywhere. Various Tekno team drivers run 17-19. Generally, we don't run any timing, as it causes quite a bit of heat for very little gain on 4 pole motors. This has worked well for me on both medium and large sized tracks. If you're often wide open at full speed, gear up. If you're never getting to full speed, gear down.
Regarding the SMC 1900, the new ones will run slightly cooler (running change made to them).
For servos, I've been mostly happy with both of these in my full eBuggy:
ProTek 150t
Savox 2274
I'm in the process of switching to the ProTek 170s as I'm going to be putting one in both the EB48.3 and the new ET48.3 I'm building. Then all of my servos will all match at .07 for eBuggy, eTruggy, and 4wd SC (an Orion servo) when run on HV.
Highest is a servo OEM for other companies, not a copy of others. I've often considered picking a few of them up, customized, but that takes ordering direct from overseas (at least, it did when I looked into doing so at the beginning of the year).
ProTek 150t
Savox 2274
#637
Thanks for all the servo comments. I'm going with the tekin rx8 gen2 esc(I think that's what they are called). Im also deciding between the m12 or 4px
#638
Make sure you buy yourself an external capacitor that attaches to your rx. You can either make your own or buy the Spektrum Glitch Buster. As far as radios, good choice on either. 4px rx's are a lot less pricey. My recommendation is to go to your lhs and hold both in your hand. Or ask some local drivers if you can hold theirs.
#639
#640
So I went with the Tekin RX8Gen2 1900KV and ESC thanks to the input on here and a deal I found on Ebay. I have the EB48.3 kit built, the servo, wheels, motor and ESC on the way. What else will I need besides lipo's to get er track ready? servo horn, correct gearing, etc?
#641
#642
You really should base your decision on what feels better in your hand like portyansky said. They are both great remotes that are at the top of the game.
#643
Thanks Eric
#644
Does the new HW XR8 plus fit in this car
