Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 03-21-2012, 03:38 AM
  #1831
Airwave's Avatar
Is anybody using the ball differential?
I find it very hard to setup... The conception seems perfect but in fact, this is really hard for me to know if i'm in "Setup mode" (with the outdrive pressed) or in "Normal mode" (with the outdrive normal)
I would try to fill the ball diff with silicone oil, just as the gear diff... But in this configuration it is very hard to keep it from slipping...
Any advice on that?
Airwave is offline
Old 03-21-2012, 05:04 AM
  #1832
Trader Rating: 27 (100%+)
Any advice on that?
It took me a couple of times to build the unit. I am about a 1/4 turn from full lock. I used 10wt oil - just enough viscosity to keep the unit under fluid. Doesn't take a lot of oil.
I have about 20 runs on the diff without a any further adjustment or maintenance.
The best advice is to follow the instructions to the letter. There is no trick to it.
MDawson is offline
Old 03-21-2012, 08:37 AM
  #1833
Cool as usual post of JD concerning our new BC1 - Battery Clamps Set:
JD RACING BLOG
Link to this product in our web shop: http://shop.awesomatix.com/index.php?productID=848
Oleg Babich is offline
Old 03-21-2012, 09:31 AM
  #1834
hana166's Avatar
Any advice on that?
It did take a while to get it right. I assembled dry and it was quite notchy, so I changed the balls to zeppin ceramic and also thrust bearing and it was super smooth. Convenient the parts are same size as Xray. Used 250cst shock oil but will change it when I can get something thinner. About 1/3 turn from full lock.
I think the slipping may be the rings themselves. Not sure but it does appear to slip more than a regular ball diff when you slip one side in the car. But when I try to slip both sides together in the diff tool its locked solid.
A almost maintenance free ball diff, now that's genius. Definitely prefer the feel but not sure if its faster than the gear diff, or when is the best time to use it.
hana166 is offline
Old 03-21-2012, 10:02 AM
  #1835
Default Driveshaft Quality/Rebuild - 3000+ lap checkup
After an estimated 3000+ laps (or about 31 hours) of track time I finally had to rebuild my front driveshafts. The shafts started to experience a little bit of slop in the eyelets of the outer sleeve.
After tearing down the driveshafts it was clear that the outer sleeves is where the majority of wear existed. I replaced the sleeves, pins and outdrive bushings, the rest of the unit (axle, bones, u-joint cross) were reusable. New heat shrink and the unit was ready to go.
Excellent wear characteristics for front driveshaft components. My other models would not have survived a 1/6th of that track time! $15 of parts after 31 hours is rare.
The better news is the rear driveshafts/axels just needed to be cleaned and they are ready to run.
MDawson is offline
Old 03-21-2012, 11:35 AM
  #1836
hello Freddy..
do u have any advices for Ride32 tires on carpet..
thanks and congrats for ur good results..
method699 is offline
Old 03-21-2012, 12:29 PM
  #1837
To be honest I made no tests yet with the tires. But I will test soon because of preparation for the next ETS round in poland.
I think the setup will not change a lot. Maybe rollcenter and droop because of the different Diameter from the tire compared to the CPX which I normally use.
I will post asap the setup when I tested with Ride tires.
FreddySudhoff is offline
Old 03-21-2012, 12:38 PM
  #1838
Team EAM
Trader Rating: 79 (100%+)
How tall are CPX tires? Ride tires are VERY tall and have a hard sidewall it seems. They give very good forward traction but no steering
EA
EAMotorsports is offline
Old 03-21-2012, 01:18 PM
  #1839
that will be thankfull man..
when you say droop and rollcenter should i go for less droop and higher rollcenter..knowing that those Ride32 tires are the red one for asphalt but we have to start the championship indoor with it..its a really pain to drive compare to sorex..
thanks
Old 03-21-2012, 01:30 PM
  #1840
CPX tires are around 62mm diameter. I don't know the messure of the ride ones. When I used Ride tires on my previous Car it pushed a lot.
I will let you know after testing :-)
Old 03-22-2012, 05:40 AM
  #1841
Thanks Freddy,
i'll wait for ur feedbacks.
have some measurements about the tire sidewall.
CPX: 5.25mm
Ride: 6.25mm
Sorex: 6.75mm
Old 03-22-2012, 08:04 AM
  #1842
Good battery pack holder JD !!!! Forget about tape !
bertrandsv87 is offline
Old 03-22-2012, 09:27 AM
  #1843
erchn's Avatar
Default Plastic universal rings
Are these rings meant to hold the universals together in the same way the inner bearing ring was used by Velocitygt?
http://shop.awesomatix.com/index.php?productID=853
erchn is offline
Old 03-22-2012, 03:18 PM
  #1844
Yes, it is the same way but our P20 rings are made of Delrin and are wider than Velocitygt's steel rings .
The pictures will be soon.
Old 03-22-2012, 03:58 PM
  #1845
Oleg - can you post a "new release" area of the site so we know when new parts are introduced?
MDawson is offline
