Like Tree6280Likes
USGT
    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech ForumsThread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Old 08-30-2014, 07:34 PM
  #3031
Originally Posted by artwork
Have not got it mounted up yet...but I did get my new Audi Body painted up!
WOW!!! I'm going to let you paint my next Audi R8 body. What do you charge?
John Wallace2 is offline
Old 08-31-2014, 07:48 AM
  #3032
Nice!
mackin is offline
Old 08-31-2014, 08:06 PM
  #3033
Adonis_mp's Avatar
Trader Rating: 9 (91%+)
I'm looking for a new motor for my USGT and want the best. I currently have a Tekin but I was told that there are others that are better suited for this. Money or name are not really an issue and we are not that stricken at my track, so give me some suggestion.
Adonis_mp is offline
Old 09-01-2014, 04:58 AM
  #3034
Team Scream has a killer 21.5 motor. It's not ROAR legal yet, but should be in the next couple of weeks. We did a lot of testing with this motor at The Gate and it's been the best so far.
chuck
mackin is offline
Old 09-01-2014, 05:43 AM
  #3035
What is your track like and how long are your races? Short straight and tight turns or like mine tracks long straights (~160+ft) and open flowing turns. We run 12 minute mains in USGT. Makes a difference on what is "the Best" if there is such a thing. Two weeks ago we had 10 cars in USGT and at least 7 of them had different motor brands and all 10 had best laps within 1 second of each other on the mid 16 second tack layout.
Old 09-01-2014, 07:14 AM
  #3036
JRnotEwing's Avatar
I still think motors can be just the luck of the draw and brand doesn't matter. Yes you can play with rotors etc. but I have a used old Thinder Power that I started with was $50. I've consistently set fast lap with it every week on a track that changes weekly. Always looking for more, I've tried a D3.5 (was slower). A speed passion (also slower). Last week I tried the new D4 but came new with a bad sensor board. All fixed now so we'll see what comes this week. But I'll carry the old TP that smells like it's burning up even tho it's only 150* to throw back in if needed.
JRnotEwing is offline
Old 09-01-2014, 10:57 AM
  #3037
Adonis_mp's Avatar
I see by your signature block that your using a 6.2 for GT, would you share with me your setup, I'm looking for a base setup.
Old 09-01-2014, 11:36 AM
  #3038
JRnotEwing's Avatar
I started with Andrew Cartwright's setup off the AE site
http://www.teamassociated.com/pdf/ca...t_ECC_2014.pdf
Old 09-01-2014, 01:55 PM
  #3039
Luck of the draw certainly helps and I feel your pain with the D4 (read the VTA thread about the troubles I had with my Much Bitched About (MBA) motor, which like your D4 were resolved by replacing the sensor board; now its one of the better 25.5 motors I have). But assuming a correctly functioning motor, I agree with you that Brand doesn't matter as much as some people think (or want you to think). Most of the newer motors (and I've dyno'd many 21.5 motors) are pretty good and with the correct timing and gearing can be contenders (even the old 21.5s I used in VTA years ago look pretty good, they just draw more amps than the newer motors). 7 different motors out of 10 USGT cars all running lap times within 1 second - probably driving skill (or in my case lack there of) is the bigger factor in the order of finish than what motor was in the car: a great driver is hard to beat no matter what motor he/she is using.
PS the speed passion motor has different timing chips, which one did you use?
Old 09-05-2014, 12:46 PM
  #3040
CSeils's Avatar
Trader Rating: 54 (100%+)
Default USGT
Ready for indoor season to start.
CSeils is offline
Old 09-06-2014, 10:54 AM
  #3041
RaceDayHobbies's Avatar
I love the root beer theme. Really nice work.
RaceDayHobbies is offline
Old 09-06-2014, 11:22 AM
  #3042
theproffesor's Avatar
Trader Rating: 66 (100%+)
Ok so I just got my tires broken in and one of them some how gets cut across the carcass from left to right. Ive put a couple layers of ca glue on it. It will be sometime before I run them again. Do you guys think that the glue will hold? Or do I need to break in a new set? Really dont want to have to do that.
theproffesor is offline
Old 09-06-2014, 11:58 AM
  #3043
I hate to tell you this but I would start breaking in a new set. The tire deflects under load and the CA will cause that small area to be harder then the rest of the tire. It will cause a "bump" in the tire. Similar to the dreaded flat spot from locking up the brakes but in the opposite direction.
Old 09-06-2014, 12:11 PM
  #3044
Tommy R's Avatar
Trader Rating: 21 (100%+)
Originally Posted by RaceDayHobbies
I hate to tell you this but I would start breaking in a new set. The tire deflects under load and the CA will cause that small area to be harder then the rest of the tire. It will cause a "bump" in the tire. Similar to the dreaded flat spot from locking up the breaks but in the opposite direction.
This was my thought, as well.
Tommy R is offline
Old 09-06-2014, 07:44 PM
  #3045
Adonis_mp's Avatar
Default Motor
Still can't decide on a motor. I need an all around cuz my track changes every race, sometimes tight and technical, other times fast with long straight. I've narrowed it down to the Orca TX, Team Powers ACTINIUM and the Trinity D3.5 21.5 Turn ROAR Spec Certified Handbuilt Motor.
