BMI's DB12R
Old 01-06-2008, 02:18 PM
  #3646
Trader Rating: 26 (100%+)
whats the normal tire choice for this car? small tight track,low to medium traction
eddie10 is offline
Old 01-06-2008, 02:28 PM
  #3647
mtbboy's Avatar
Thought you never posted Ev?
mtbboy is offline
Old 01-06-2008, 02:31 PM
  #3648
protc3's Avatar
Trader Rating: 13 (100%+)
yellow rear and 2x pink front seem to work very well. For jack the gripper tracks i like both purple/gray and purple/yellow
protc3 is offline
Old 01-06-2008, 02:32 PM
  #3649
trying to get some tire advice
eddie10 is offline
Old 01-06-2008, 05:10 PM
  #3650
Trader Rating: 17 (100%+)
Ive ran nothing but yellow/lilac so far and can say it is totally dialed. You can make lilac/2x pink fronts with similar results depending on the compound you decide to apply to your front tires. Lately I have been running about 2/3 compound on the fronts and its working perfect. Yellow rears seem to be the ticket for keeping the rear end of the car as free as possible while still providing the traction people want. I have been running them in both stock/19t and while they wear quite fast they work great.
Kave is offline
Old 01-07-2008, 11:12 AM
  #3651
Applesauce's Avatar
Trader Rating: 15 (100%+)
Default Dampening tubes?
What effect will thinner or thicker lube have on the car?
Applesauce is offline
Old 01-07-2008, 02:34 PM
  #3652
fatbear's Avatar
You have a PM Jason.
fatbear is offline
Old 01-07-2008, 05:31 PM
  #3653
protc3's Avatar
Thicker dampening slows the reaction of the side springs and thinner allows it to travel more freely. When you slow the reaction down it will give the effect of more steering because it allows the side flex plates to transfer and return the energy or weight to the front tire over a longer period of time. Thinning the side dampening out has the opposite effect. The key is to find the ideal balance for your track conditions. If you go too thick it can cause the car to chatter through corners or lifting an inside rear wheel.
If the car is rolling too much and not carrying corner speed, this can be because the car is rolling too much and may need thicker fluid in the tubes. The car should be smooth and not be darty. If you get the fluid right, the car will transition smoothly and keep its cornerspeed while doing so. There are other variables also so i would start with the kit setting and save the damper fluid as one of your last adjustments.
protc3 is offline
Old 01-07-2008, 05:48 PM
  #3654
xtrememadness's Avatar
hey jason when if ever would you need or try a front brace? my car is pretty dialed for the most part but i always feel like i can be faster
xtrememadness is offline
Old 01-07-2008, 07:24 PM
  #3655
protc3's Avatar
Once you get into the medium to high bite conditions, A front end brace will help find those tenths you are looking for
protc3 is offline
Old 01-07-2008, 10:53 PM
  #3656
Uga
Uga's Avatar
I just put the L4 brace because everybody else are having one and the car looked like stripped without it
Uga is offline
Old 01-08-2008, 02:47 PM
  #3657
fatbear's Avatar
Jason, you have a PM.
fatbear is offline
Old 01-08-2008, 09:40 PM
  #3658
PW
PW's Avatar
PW is offline
Old 01-09-2008, 03:12 AM
  #3659
protc3's Avatar
Nice brutha Someone is ready for this weekend i see. all you need is your stock motor and your ready
protc3 is offline
Old 01-09-2008, 07:34 AM
  #3660
ChestyV32's Avatar
Trader Rating: 32 (100%+)
damn i think he is the only one ready LOL
2 more days of work and then friday im off to the races
ChestyV32 is offline
