Hot Bodies TCX
Old 02-01-2011, 06:20 PM
  #2026
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
How are you fitting 4mm of shims in total for the front wheelbase Mike? And also, what did you find using no sway bars did?
Thanks,
Antoni
Last edited by Yokomo_Ant3; 02-01-2011 at 06:42 PM. Reason: needs to learn to read :P
Yokomo_Ant3 is offline
Old 02-01-2011, 06:23 PM
  #2027
syndr0me's Avatar
Trader Rating: 32 (100%+)
Congratulations on the win, Mike, your car looked fantastic.
A couple of questions:
How wide do you run your car? Doesn't the HB typically run pretty narrow?
Did you try an LTC-R at the race? Why'd you end up with the speed6?
syndr0me is offline
Old 02-01-2011, 06:28 PM
  #2028
Widths are on the setup sheet, 187 front, 188 rear. Mike is only using 1D of arm sweep, so a lot less than kit.
Old 02-01-2011, 06:34 PM
  #2029
Team EAM
Trader Rating: 79 (100%+)
Mr. Haynes.....AWESOME job for the 2nd race in a row! You drove a smart race and awesome win! You going to the Nats?
EA
EAMotorsports is offline
Old 02-01-2011, 06:52 PM
  #2030
syndr0me's Avatar
Ah, I missed that, thanks.
syndr0me is offline
Old 02-01-2011, 07:06 PM
  #2031
Trader Rating: 77 (100%+)
Where can I get the 1.1 mm 3 hole pistons? Also what does having so little (2mm) of droop do? I run 8.5 mm of course on a different track. I was just wondering.
goin2drt is offline
Old 02-01-2011, 07:11 PM
  #2032
Mike Haynes's Avatar
Originally Posted by dameetz
Mike, what pivot balls and ball ends did you use on your car? Does it eliminate the slop?
They are losi type r ends, perfect fit for the hb ballstud, yes no slop
Thanks,
Antoni
I have a normal 1 degree block dremeled to fit on the inside, it has a different offset
Thanks, i ran my mod car more narrow for grip, but wanted stability for the stock car. The ltc was making the car very nosy and a bit hard to handel, so i swapped it out for stability sake.
EA
All i kept thinking was go slow dont wreck lol....no carpet nats for me, i'm going to go to the superstock race in NM later this month then im done traveling till the paved nats.
I have schuie 3 hole pistons in mine, and just drilled out the holes larger. My droop is measures in mm over ride height not total uptravel, so its not too much more...basically just keeps the car flatter in tthe chicanes.
Mike Haynes is offline
Old 02-01-2011, 10:08 PM
  #2033
Great job Mike!!
Hi-LowBlow is offline
Old 02-02-2011, 04:36 AM
  #2034
k_bojar's Avatar
Trader Rating: 30 (100%+)
Hey mike - who's upper bones are you using in the rear?? If it's in the setup sheet, I apologize can't see the setup on my phone
Are the the HPI pro-d ones??
k_bojar is offline
Old 02-02-2011, 05:21 AM
  #2035
I have the cyclone 44mm steel in rear and top 46mm steel in front. Top pin retainers all around
Old 02-02-2011, 06:28 AM
  #2036
SammyZ's Avatar
Trader Rating: 138 (100%+)
besides the invention of yokomo, you are the greatest thing that has happened to R/C.
SammyZ is offline
Old 02-02-2011, 07:04 AM
  #2037
san.'s Avatar
Trader Rating: 61 (100%+)
Originally Posted by Hi-LowBlow
Great job Mike!!
Thank him with a Factory Team Contract.
Mike has helped me a great deal with my TCX @ Horsham. The guy is an ideal ambassador for HB/HPI.
I'm sure Alex and Jerry can agree as well.
san. is offline
Old 02-02-2011, 07:27 AM
  #2038
Old 02-02-2011, 09:33 AM
  #2039
Default Mike Haynes
Hey Mike,
Which spec r gears diffs r u running in your tcx and what mods did you have to do to make them work?
Congrats by the way!!
Matt W is offline
Old 02-02-2011, 10:36 AM
  #2040
dameetz's Avatar
Has any of you ever use 6 degs caster c hub? I m asking because recently I ordered 4 sets of c-hubs part #73518(4 deg caster) from one of the HK online shop, strangely all of 'em contain 6 degs caster c-hubs. If I use it what changes in handling am I expecting?
dameetz is offline
