T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 11-10-2010, 12:40 PM
  #6211
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
If you guys look at my setup I am not using the Longest position on the Optional camber link plate. I do not like that long link at all. It makes the car feel super lazy to me and feels like it takes away steering.
I run the middle hole on the optional plate. If you put the optional plate on top of the stock plate and look at them you will see that the middle hole on the optional plate is directly in between the middle and inside hole on the stock plate.
Running this position in the front and the middle hole on the stock plate in the rear with the shimming I have on the bulkheads for the width It gives me almost perfectly equal camber link lenghts front and rear. To me this makes the car roll very evenly thought the entire corner while maintaing a balance of rear traction and steering.
This is just how I feel it may not work for everyone.
Like OD said I run the Stiff lipo chassis that comes with the car now. I have been using the stock rubber topdeck as well this whole season. And my car has been the best it has ever on carpet the last couple of weeks.
L.Fairtrace is offline
Old 11-10-2010, 01:26 PM
  #6212
hana166's Avatar
I think the long link is something good to try. Its good to experiment.
Some of the best drivers I know hate it, and told me so..but laptimes were better and more consistent for me this way in general. I think it could depend also on other aspects of set up, but mostly driving style. Perhaps might have been done first by Masami, he's pretty quick !
Usually you prefer your own car to someone else's even when they are quicker than you
hana166 is offline
Old 11-10-2010, 07:02 PM
  #6213
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
I wanted to take a second to share some videos with everyone. They are of some very special dogs doing something very unique. They are practicing for an upcoming event to benefit the Henry Wrinkles Foundation. If you like what you see PLEASE forward the links to everyone you know.
http://www.youtube.com/watch?v=MkXoD583A14
http://www.youtube.com/watch?v=jssiWt2Jyx4
http://www.youtube.com/watch?v=NEOx2hSf-Es
mrrcguy is offline
Old 11-11-2010, 01:08 AM
  #6214
Questions?? GOT MYSELF A PHOTON - PARTS ADVICE
I have got myself a Photon - got it second hand for 132 - the person who had it before me had one arm the wrong way round to the other side, shims in one side that's not the same on the other side
I think the last owner gave up after one run as the car is unmared.
Now I have a few questions:
1. How can I tell if I have a v1 or v2 shock?
2. are any parts interchangeable with other cars - in particular are the steering arms interchangeable with TAmiya ones
3. IS the Lipo chassis a worthy upgrade?
4. should I flip the belt on the current chassis?
5. to stiffen the car up shall I just get the US Foam parts - (I am running indoor rubber set up)
tips will be appreciated
Lohan
Lohan is offline
Old 11-11-2010, 01:43 AM
  #6215
sosidge's Avatar
Not a surprise to hear that... I've seen plenty of people "give up" on a car over the years, and then when you look at it, they have assembled it wrong...
Lohan
A few rough answers...
1. If you open up the bottom seal on the shock and the parts are black it is probably a v1.
2. I don't think its worth going down that route. Any change will have knock on effects down the line. The car can be made to work just fine with TOP parts.
3. I still run 6-cell chassis (with a custom-made LiPo tray, although it isn't even necessary). Haven't tried the dedicated LiPo chassis.
4. If it will allow you to, yes - although it sounds like you have the standard 6-cell chassis, so flipping the belts requires some Dremel work - not worth it in my opinion because the balance gains from flipping the belts are small, and the risk of weakening the chassis is slightly higher.
5. Indoor rubber with the 6-cell chassis - go with the rubber medium top deck. All the other parts rubber kit. That should be stiff enough.
sosidge is offline
Old 11-11-2010, 03:10 AM
  #6216
Cool Hi
Hi Sosidge
I was only asking about interchangeable parts, coz if I did damage anything at a track without the Top part, I could use another part. In addition to that I see Top do that thing Yokomo used to do - ie. a rear hub carrier, and front steering arm together, instead of pairs of steering arms
When you say the shock seal - do you mean the top of the shock, or the bottom. I am told their were problems with the v1 - how does one resolve it if one has a v1. I must say that the shocks do feel perfectly smooth to me!
Lohan
Lohan is offline
Old 11-11-2010, 03:41 AM
  #6217
sosidge's Avatar
Hi Sosidge
Lohan
Well, I sit here with a new rear upright for my M-05 in front of me... that comes attached to two front uprights, another rear upright, two c-hubs and a selection of spacers... so getting a front and rear upright in the same pack is not so bad! You'll be going some to break any Photon mouldings mind you...
I think the v1 shocks are fine also. I mean the bottom of the shock. You can buy the newer white shaft guides if you feel the shock needs updating. I should confess that my Photon Shocks have Tamiya seals, shafts and pistons in them though...
sosidge is offline
Old 11-11-2010, 05:31 AM
  #6218
Cool Cheers
Thanks for the help m8
I am using it tonight, and am curious as to how it's gonna be when I take it for a spin. I had a tired 008 thyat was nice to drive, I also sold an mi4lp (hated it). I used a cyclone for 2 years before that.
I hate 'car hopping' and much prefer trying new parts/options until I feel happy!
I will report back, and thanks for the help once more.
Lohan
Lohan is offline
Old 11-11-2010, 04:04 PM
  #6219
Trader Rating: 26 (100%+)
Originally Posted by L.Fairtrace
Here is my most recent setup. It works very well. Our bite was really high this week and there was zero worry of traction rolling while many other cars were.
I suggest if you are going to try the setup please do the whole thing exactly how it is listed. Putting half a setup on is not trying the setup.
Change your shock orings to the 40 degree ones and put fresh ones in when do this setup. Its very important to have perfect working shocks for this setup to work good.
I would suggest reading my shock building tutorial on Hanulecs Wiki.
On your above setup it shows 0mm for swaybar front and rear. Is that correct no swaybar front and rear
eddie10 is offline
Old 11-11-2010, 04:43 PM
  #6220
Jerry P's Avatar
Trader Rating: 44 (100%+)
Most likley. Larry doesnt usually run sway bars..
Jerry P is offline
Old 11-11-2010, 05:02 PM
  #6221
hanulec's Avatar
Trader Rating: 28 (100%+)
Yeah - no bars...
hanulec is offline
Old 11-11-2010, 05:16 PM
  #6222
The current car if bought int he USA comes with an extra set of plastics.
It comes with the chassis I am running. It comes with the new shocks.
I would really only suggest you "need" the optional camber plates and all the Rubber springs 393,367,324,289.
The car pretty much comes with everything needed.
I have been liking the optional machined 1.2 pistons recently also. But that is not needed to be fast.
These optional 1.2 pistons are they the same as one of the sets that come with the kit.
eddie10 is offline
Old 11-11-2010, 05:18 PM
  #6223
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
No he's talking about the new machined option pistons. The kit pistons work just fine though.
Ron Goetter is offline
Old 11-11-2010, 08:11 PM
  #6224
rcmike's Avatar
Trader Rating: 40 (100%+)
Default battery tray length
Can someone measure in mm what the longest length is on the battery tray for a lipo that you could have in the car ? I have some nano techs that i would like to see if i could use them to power a sedan car. thanks
rcmike is offline
Old 11-12-2010, 08:50 AM
  #6225
TAMAK's Avatar
Trader Rating: 29 (100%+)
Hey guys, I broke a front steering knuckle on my photon and took it apart. somehow I lost a kingpin collar. I bought this car used so I have a bunch of spares. However, some parts look different then other and some kingpin collars do not fit on the front C hub.
Can someone give me an idea of what parts I should get to redo the front end, so its modern to todays parts? Thanks!
TAMAK is offline
