BMI's DB12R
#1951
Jason -
I'd like to purchase the ride height adjusters and axle spacers. How many ride height adjustment sizes are there now? I might just buy them all from you and if you can just charge them to the credit card you have on file for me? I'm in D.C. this week and won't be able to call before your normal closing time.
btw: the car is getting better each time I go out. Had a decent run with it on Sunday. But I'm still not happy with my speed. Must go faster! I have some more thing I am going to try this coming weekend.
Regarding tweaking - the car does not tweak. I had some glitches on Sunday that sent my car flying off the track at the end of the straight (hard left launched it) that split the top graphite motor plate and bent the top shock cap. so, it was a very hard hit. However, the car did not tweak!
The cool thing is that on Saturday when I was prepping my car, I had tried some different shims on the front end. My side to side ride height was off by .5mm at the droop point. I new my tires, etc were all set and the only thing I changed were my (plastic) shims. I took those out, replaced them with metal shims that I had measured, and the inconsistent ride height was gone.
-Rich
-Rich
#1953
#1954
We kept with Jack the season after the carpet nats but for some reason the rubber TC tires and the Jack put down a weird coating on the carpet so the 12th scales would only have traction for a few minutes then be very very loose. Switching to Paragon fixed that, but at a slight cost of smelly-ness.
#1955
Well here is mine! Its about 90% done... (Notice the missing shock) and needs a transponder..And carve in Parma bumper..
Hi-res pics are the thumbnail pics below the 640x480 pics. I appreciate good pics of cars as you do to, so I am returning the favor.
I did cut, shorten, and solder the ESC wire undernieth the gtb solder tabs, so there isnt any confusion, Need to shoogoo the Cap down to!
(Dont mind the old SMC.. lol new ones are on the way!)
(Ill send adrian the final pics once it is 100% done and the new body mounted on her)
12th scales are the COOLEST!!!!!
#1956
#1958
Hey guys,
I finished the rear axle shims today. They are axle shims that are designed for use with the Jaco Prism wheels. They will set your rear axle at 172mm and with 1 on each side will center your axle also so there is now headaches of achieving center or 172mm. They are now available.
#1959
Jason -
-Rich
-Rich
Cool deal bro. I will get them out today. The front shims come in 6 sizes. You can run full size tires down to the rim in .5mm increments.
#1962
#1964
Hi Jason,
Cool - go ahead and send/bill me the entire set plus the axle spacers. Oh, can you also send/bill me:
- another carbon fiber top deck for the motor mount.
- 3 more sets of the pivot balls/pivot ball holders assembly that is for the hockey-stick tweak plates. I want to have those so I can just easily swap in an assembled tweak plate to try different thicknesses.
Charge it all to my credit card.
Thanks!
-Rich
Thanks!
-Rich
