Like Tree86Likes
Hpi Pro 4
Old 07-20-2004, 12:09 PM
  #6256
kewdawg's Avatar
Originally posted by Kraig
Losi spool pads are a-3250.
Good lookin' out, Kraig! thanks
kewdawg is offline
Old 07-20-2004, 03:26 PM
  #6257
azenis's Avatar
Originally posted by Skill
Looks like Hara is running carbon fibre camber link mounts, but just carbon fibre which fits over the stock mounts. He's also running purple spring perches
Also, does anyone know what those purple bits are on his steering knuckles?
I have seen these on other cars, but what are the little purple washer things under the heads of the steering post screws for?
azenis is offline
Old 07-20-2004, 03:33 PM
  #6258
rc-zombies's Avatar
read top of page and work your way down...and you'll find the answere to your question.
rc-zombies is offline
Old 07-20-2004, 03:40 PM
  #6259
azenis's Avatar
ahh this page or the start of the thread?
titanium screws?
having looked at the pic again i notice that they are also on the screws at the end of the gear box, and these scews are normally round heads, and changed to countersunk looking ones, so i would gather the washers are there for the countersunk head to fit into
azenis is offline
Old 07-20-2004, 06:18 PM
  #6260
rod_b's Avatar
"concave washers"
rod_b is offline
Old 07-20-2004, 07:12 PM
  #6261
Originally posted by Frank McKinney
I'm not sure that Thad was racing, I didn't see his name in the full results. I would think he was but I don't know for sure.
I wasn’t racing, just PB-ing (pit guy) for the MAN!
Hara's set-up from the race..
This setup sheet is 99.9% accurate. He was making changes every run due to constant track temperature changes.
azenis,
We sometimes use o-rings and concave washers on the steering post screws to eliminate and possible tweak when using the 2.0mm chassis. This isn’t as necessary with the 3.0 and 2.5mm chassis. The reason he is using the Washes and counter sunk screws on the gear box is because he was using the Carbon fiber braces.
pro4_chris,
RPM Part# 73372 Heavy Duty Rod Ends (12) 4-40 (Black)
www.rpmrcproducts.com/products/assoc/hires/7337.htm
Thad Garner is offline
Old 07-20-2004, 07:17 PM
  #6262
azenis's Avatar
Originally posted by rod_b
"concave washers"
where do u get them? and are the Ti screws less prone to rounding?
azenis is offline
Old 07-20-2004, 07:21 PM
  #6263
azenis's Avatar
Originally posted by Thad Garner
azenis,
Thanks for that Thad How does it reduce tweak?
I run a 3mm BMI chassis on tarmak, so I guess I dont need them
I havent found any setup sheets on the net for 3mm esp for asphalt, do you know of any?
TIA
azenis is offline
Old 07-20-2004, 07:24 PM
  #6264
coastaltony's Avatar
Trader Rating: 13 (100%+)
Sorry for being a pain, but my server can only read jpg's
coastaltony is offline
Old 07-20-2004, 07:43 PM
  #6265
S15Racer's Avatar
Originally posted by xxxkat
All I can say is if you cant get a Pro4 to handle..go back to offroad.. I do have a question,Why would you put associated springs on the car before trying the stock springs.. If the 32's were not working,why not try 27's first,rather than drop to 23's,are you using the kit oil..or did you change that also..just asking,so dont get upset.I just read on this board about how some guy's cant get their Pro4's to work and the one's I have are soooo dialed using the stock set up(but with no sway bar)at the track I race at my car is so hooked up I'm running Yokomo sprints (firms with soft inserts)Most guy's at our track can't use them.. I am just as interested in understanding why your Pro4 wont handle as you guy's are,on the "stock" setup are you running it as the book says to,or have you made "improvements"ie: camber,caster..etc.I'm just interested in the setup as far as "stock" goes.
OK, to start from the beginning... When I originally came up with this set up I had tried the stock springs first and found that the AE springs made it handle more aggressively, thats why I used them first on race day. Why didnt I try 27's? that a pretty simple one- I didnt have any! Yes I was using the kit oil, the only things I changed were the things I mentioned in my original post.
Jim! I was pretty close Thanks again for the arm and for the set up, I'll try that this sunday and see where I am. That is assuming were outside again on sunday, I hear theres a chance of r*** on thursday and friday I should also have my new servo in by then so at least it'll go straight down the backstretch eh?
S15Racer is offline
  #6266
72063 6 Cone Washer 3.0mm/4-40 Aluminum (Purple / 6 pcs)
http://www.hpiracing.com/graphics/parts/72063.jpg
The o-rings reduces chances of chassis tweak by allowing the chassis to flex without the screws binding and sticking.
I have found the Ti screws to be a bit softer.
We use the 2mm chassis for asphalt racing. It produces more traction.
Old 07-20-2004, 08:01 PM
  #6267
azenis's Avatar
Hi Thad
Where can I buy that part? never seen them... will check tower
So you use a 2mm chassis. how does that creat the extra traction? More flex? I would have thought flex to be a bad thing? I think the 3mm would be less prone to tweak as well?
Should I invest in a 2mm chassis?? our track is a school yard, and as such is a pretty bumpy and uneven surface, however they are building a new proper track for us which will have a perfect surface, but i dont know when it will be finished (its a long way off)
azenis is offline
Old 07-20-2004, 08:03 PM
  #6268
azenis's Avatar
Oh and I meant to ask you...
The setup sheets for the 2mm chassis and 2.5mm, will they still work ok with my 3mm chassis?
I do have the standard one as well but the 3mm chassis is on the car at the moment, as i bought it that way...
azenis is offline
Old 07-20-2004, 08:41 PM
  #6269
Trader Rating: 2 (75%+)
Thad,
Why do you prefer taping your batteries in then using the plastic battery holder? Is it for saving weight or for more secure batteries on the chassis??
PUNISHER is offline
Old 07-20-2004, 09:14 PM
  #6270
azenis's Avatar
do these washers include the o-rings or are they another part?
azenis is offline
