TRINITY MOTOLYSER ANY GOOD
#91
also the Asymmetry measurement is one of the best features, You can really feel it when you drive if you have a good one
#92
I severely doubt that a software update will allow the GForce unit to give you the amp draw of each phase, I think that would require a hardware change and up the price as the digital ammeter is probably a good chunk of the cost. I think the ability to measure the individual phases will remain the advantage of the Motolyser, and if people are hard-core (like oval guys, who traded in their sanity for an extra tenth a long time ago! ) it may be worth it.
As for the motor I tested, it was a Team Powers motor, not an R1. I have also tested my Tekins, Trinity Duos, LRP x12 and X20, and others and all required a little "massaging" and centering of the sensor board to get it closer to perfect.
#93
#94
Simpler? I strap my GPS to the car and run it down the street. Gives me max mph right on the screen.
Thanks but I have an even simpler way to calculate the speed of my car (without a speed gun) and you don't need all those measurements (e.g., do you know the KV rating of your motor with the amount of timing you are using? - I do but I have a Motorlyser). I run my car flat out in the street in front of my house, download the RPM from the ESC, divide by the FDR and I have the wheel speed in RPM. I can convert that to MPH, KPM, or any other unit of measure I want.
#95
Hi Guys,
I bought my self a Motolyser and I have some questions.
My motolyser shows a 0.15 volt lower supply value. Is there a way to calibrate this?
The Motolyser shows drifting timing values with the same motor and the same settings
1 run 32.5, 36.6, 39.0
2 run 34.5, 35.5, 35.9
and so on.
Have you noticed the same drift or have you stable values?
Thank you
and so on.
Thank you
#96
Hi Guys,
and so on.
Thank you
and so on.
Thank you
#98
When the high current draw occurs I just turn down the timing on the end bell.
If you don't mind, which motor(s) and at what timing do you see it? If I have the same I can run a test. Otherwise email them, I've found them to be very responsive.
#100
Can't say that I have, but then again I haven't re-tested all my motors. Wish they would make a USB readout available as they claimed was possible.
Kill Shot Maxilla 17.5 58 degrees on end bell (~45 degrees)
#102
I read on here somewhere that the new version had a current cutoff to keep people from burning up the unit.
#105
these checkers seem great for getting motors to the same settings but how do you know what settings are best?
example: i buy a motor, throw it on the checker and sure it gives me info. then what? what am i looking for in the data that tells me to +/- timing or change to a different rotor, etc..? do you first run the motors on track to set them to the best performance, check 'em and then use that as a baseline and just set every other motor up to those settings?
