Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 02-01-2015, 11:28 PM
  #421
DaveG28's Avatar
Trader Rating: 65 (100%+)
Hi guys,
Loving the build on mine so far, one query, is it ok/usual to have a lot of float in the front spindle king pins... Eg they move up and down vertically a fair bit in the hub?
DaveG28 is offline
Old 02-02-2015, 01:16 AM
  #422
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
Mine moves quite a bit there doesn't seem to affect the driving. But I'm going to try and pull some slop out.
Ultraspeed84 is offline
Old 02-02-2015, 03:21 AM
  #423
pumpkinfish's Avatar
Originally Posted by Ultraspeed84
My car was little loose but I just put 2mm washer on rear camera link on tower side, then I moved shock all way in on rear arm, short wheel base, and 0 spacers on front tower.
Can you post a full setup sheet? What kind of surface are you racing on?
pumpkinfish is offline
Old 02-02-2015, 06:09 AM
  #424
Should be posted a few pages back, and it's medium Bite dirt. Indoor
Old 02-02-2015, 11:48 AM
  #425
This is the set-up i used at Amain.com/Outback Raceway. Car was extremely good!
File Type: pdf
nitrorush27 is offline
Old 02-03-2015, 05:03 PM
  #426
Trader Rating: 358 (100%+)
Anybody using the 1.6 tapered pistons.
jmoneym is offline
Old 02-04-2015, 12:35 AM
  #427
Yes.
dennisV is offline
Old 02-04-2015, 03:41 PM
  #428
Here is a quick blog post on my car. I have let a couple people drive it and they are sold. So far extremely impressed. I have not been serious about racing in a long time, and I think this car just gave me the itch I needed to get back into this game.
http://blog.amain.com/yokomo-yz-2-setup/
Old 02-04-2015, 06:46 PM
  #429
STLNLST's Avatar
Trader Rating: 32 (100%+)
Great day of practice. Car is hooked up at LSR. Car works everywhere I race. Will not have an issue going from track to track. Will get more testing again tomorrow.
STLNLST is offline
Old 02-05-2015, 10:07 AM
  #430
joehundy's Avatar
Trader Rating: 15 (94%+)
Originally Posted by DaveG28
Hi guys,
I used Axle shims and put 2 on the top outside of the spindle and that took care of it
joehundy is offline
Old 02-05-2015, 10:10 AM
  #431
WillS's Avatar
Schelle B5 spacers work great to fix slop.
Link here
WillS is offline
Old 02-05-2015, 12:04 PM
  #432
Jack Smash's Avatar
Trader Rating: 35 (100%+)
My car is good up here. Could use a bit more forward bite but I dont want to give up any on power steering to get it. Steering feels so direct and precise, like running a 1/12th car.
Went to a Losi yellow rear spring as the car felt like it was dumping over on power at corner exit, and went to 0 zero ballstud washers in front to calm the front just a hair on entry.
Jack Smash is offline
Old 02-05-2015, 01:34 PM
  #433
WillS's Avatar
Well looks like not enough interest for MIP to make aluminum pucks for our cars. Back to the machinist I shall go. I have 4 sets of the 10 I need to send to him to make the run of lightening the outdrives.
WillS is offline
Old 02-05-2015, 08:05 PM
  #434
I used 1 washer between top spindle and bushing took all slop out
jake alton is offline
Old 02-05-2015, 08:12 PM
  #435
STLNLST's Avatar
Another great day of practice. Motor and gearing is perfect. My testing is with Tekin motors only. They run differently than other motors. The car acts like it wants a slightly stiffer spring front and rear. Currently on Kyosho whites all around. Once I'm confident in the setup I will post it.
STLNLST is offline
