Durango DEX210 Thread >
Like Tree80Likes
Old 03-08-2014, 11:26 AM
  #13981
Originally Posted by F1AZURE
Looking for m4 scrubs for the dex210. Would rather have new but if you have them mounted that's fine. Send me a message if your willing to sell them.
I dont think they make m4 scrubs for up front 2wd. Havent seen em before and have looked. They have suburbs m4 for upfront
glenng is offline
Old 03-08-2014, 05:35 PM
  #13982
Originally Posted by flame56mx
I had better luck with less anti-squat (0) in MM. Its going to be a tough job trying to use the same set-up on dirt and carpet, unless the dirt is the highest of bite IMO..
Yeah thanks i thought 0 antisquat would be better but all the setup sheets i looked at had 3 , im not trying to keep one setup for both carpet and dirt just dont want to go from mm to rm
thefan is offline
Old 03-08-2014, 06:22 PM
  #13983
Trader Rating: 520 (100%+)
Gotcha, and I agree with you, going from rear to mid wouldn't be much fun.
flame56mx is offline
Old 03-09-2014, 11:15 AM
  #13984
Do you guys think they will make the Phantom body for the 210? I love the look!
cripplethreat is offline
Old 03-09-2014, 11:30 AM
  #13985
Lead-Lobber's Avatar
Location: Currently live in southern AZ, or closer to northern Mexico if your a realist.
Default Another ball cup/ ball stud question...
Hey guys, horrible day at the track yesterday. Never finished a full run...
Here is what happened. I caught a pipe and popped the drag link from the servo horn to the steering bell crank. OOOPS, My bad.
Well, it was never the same after that and kept popping about every other lap. Damn...
So, now what is the fix for it? Order the stock parts, or replace aftermarket?
Part numbers for aftermarket?
Once again, you guys rock with the wealth of knowledge.
Cheers. Jeff
Lead-Lobber is offline
Old 03-09-2014, 12:18 PM
  #13986
I personally run Lunsford Punisher turnbuckles and ball cups and ball studs from the 22. I even run this setup on my vintage cars. No problems ever.
fredswain is offline
Old 03-09-2014, 12:23 PM
  #13987
Trader Rating: 29 (100%+)
Lunsford, they are pricey buy they are worth it!
Walkman is offline
Old 03-09-2014, 01:33 PM
  #13988
rcjunky1's Avatar
He's poping the link to the rack, no a camber link or toe link. You want the dimecx ball cups, that should solve everything.
rcjunky1 is offline
Old 03-09-2014, 02:26 PM
  #13989
Default cheers
thanks RCjunky1. That's the ticket.
Old 03-10-2014, 07:00 AM
  #13990
Dino_D's Avatar
If you use the stock ones, once you pop it, just replace it with a new one. Or like Junky said, get the new dimex
Dino_D is offline
Old 03-10-2014, 07:01 AM
  #13991
Default Cassis length?
Did someone see, that TD have got the options for different chassis lgth on the new V2 setup sheets?
There is the option for standard, for +8 and +24 length!?
Do you think that there will coming a +24 chassis, or do you think, that is a mistake?
micholix is offline
Old 03-10-2014, 07:03 AM
  #13992
I use those ball cups and ball studs from the 22 as well.
Old 03-10-2014, 07:17 AM
  #13993
P6
Losi 22 cups and ball stud with Lunsford turnbuckles i havent popped one yet it did add a few grams being the ballstuds are 4.8mm and steel
P6 is offline
Old 03-10-2014, 07:35 AM
  #13994
Default cups
Are there any worries with cutting down a ball cup to fit the length needed in that drag link to the rack? Its a short tiny thing...
And what lenght ball studs. Losi has varying lenghts, from 6mm to 10mm I believe. I don't have access to my build manual. Does it list the sizes in there?
Last edited by Lead-Lobber; 03-10-2014 at 07:59 AM. Reason: not enough coffee yet...
Old 03-10-2014, 08:10 AM
  #13995
The ball studs and cups that Losi uses on the steering rack are smaller than all of the others. They are the same size as the old smaller pieces such as those used by Associated or the previous Losi pieces. These are unique to that location.
