Turns in brushless motor needed to move a 20lb car
How much turns does a brushless motor need to move a 20lb car?
Is 21.5 turns sufficient?
turns kinda refers to a 1/10 scale ...id go with a large size motor ... are you running thru a gear box..? a 2200kv 550 or larger if you think you need...with the correct gearing will move a 20 lb truck or more... esc? cells? battery type?
I think you'll need an 1/8th scale 4 pole rotor motor like this:
http://www.smc-racing.net/index.php?...y&path=112_125
please help im desperate right now, proj due in less than a week, and nothings working. i installed 2 21.5 motors on a small wooden board and when i run the motors, the esc beeps once and then stops. i was wondering if this motor has the torque to do anything
The only thing I can think is that you may not have calibrated the ESC to know the full throttle and full brake positions (in the manual). Otherwise I don't see why the motors wouldn't at least move. If the item is too heavy at worst the motors/ESC would overheat and die. But keep in mind, what you're doing is experimental. None of us will really have an answer. We can just suggest things and you can try them. It's all trial and error.
