lipo acting strange, yet cells all show ok??
my buddies 4 cell 5000mah lipo seems to not give that much power, and sometimes inconsistent. cells all check ok??
yet when i try another battery on the same systems seems to be ok?
1.5 years old. i would have it stored properly only used it once.
no doesnt get hot and is not puffed or swollen
Like Mark mentioned, lipos are affected by age, capacity and performance drops off. But might as well try cycling it a few times, could get some, not all, back. Just don't over discharge of course.
Cycling a few times?
Yep, just charge and run, repeat a few times.
If you have not been balance charging, this could be part of the problem - more so with a multi cell (2s, 3s, 4s) lipo. You want to do this whenver possible. You could have a cell or two that is very weak and one that is overcharged.
Suggest discharging with your charger, then balance charge, - repeat 2-3 times.
I figured if u chose charge with the small white connector attached it would still balance it
I thought discharging was frowned on?
Generally discharging isn't needed, but this isn't generally. Need a reasonably high discharge rate to 'wake' the pack up, why I suggested just running it. Unless you have high rate discharging capability, up around 20 amps or so. Most lipo chargers don't even come close to that.
Be careful not to over discharge, stop short and be safe the first time or two. And check the cell voltages before starting the charge, most chargers will do that if you find the right screen. All cells should be at least 3.7V at rest before charging for best pack life.
I have accucell-6
I'm not completely familiar with that charger, but I believe it works like most so you should be good.
Oh, one other time to discharge. Best to not store packs at full charge, should be somewhere around half charged. If you end up with a fully charged pack then discharge some. Use the storage setting if your charger has it. Resting voltage per cell in the 3.75 to 3.85V range works well.
