Go Back  R/C Tech Forums > General Forums > Rookie Zone
CVD poping out--B3 >
CVD poping out--B3
CVD poping out--B3
Old 02-12-2012, 08:36 AM
Default CVD poping out--B3
Hello:
I have an old B3 that I am trying to get going. I have a problem with the CVDs popping out. It looks like the CVDs are too short.
I have googled this mulptile times and am confued aobut my options.
From what I have been I could go to a
1. Thunder TIger CVD--which appears longer
2. Convert to a B44 type setup
3. Shim the axle
What is the best and easier solution. It all has me confused and frustrated.
dwjb is offline
Old 02-12-2012, 10:09 AM
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by dwjb
Hello:
3. Shim the axle
You mean it's popping out of the outdrive? If that's the issue, you probably have too much droop on your shocks. A better option is to put some spacers in your shocks under the pistons to limit how far down the arm will go and by extension, how far out in the outdrive the cvd can get.
MarkA is offline
