Go Back  R/C Tech Forums > General Forums > Rookie Zone
MMP Help-no brakes >
MMP Help-no brakes
MMP Help-no brakes
Old 02-10-2012, 10:09 PM
Default MMP Help-no brakes
Hi all. I need some expertise. I've been using a MMP with a sensorless motor and just recently upgraded to a Novak sensored motor. I have done the manual setup and everything seems to work except when I hit the brakes it goes immediately into reverse. Again, the brakes worked fine before the motor switch and the mmp was just recently returned to me from Castle after repair. I currently use the DX2S. Any help would be greatly appreciated!
Kenjim is offline
Old 02-11-2012, 12:29 AM
Trader Rating: 52 (100%+)
Get a castle field card or USB there a must have I have the same setup
thedopeshow is offline
Old 02-11-2012, 03:11 AM
m_zaller's Avatar
Trader Rating: 11 (93%+)
You need to set endpoints for the esc and the new motor. With the esc off and the radio on hold the throttle to the full forward position, and turn on the radio. wait for the tone and then release the throttle to the full reverse postion, agian wait for the tones, and then go to full neutral. wait for the esc to show the yellow led and then turn off the esc and then motor. That should calibrate your endpoints. Hope that works for ya.
m_zaller is offline
Old 02-11-2012, 04:34 AM
hotrod87's Avatar
Trader Rating: 252 (100%+)
Yes making sure its calibrated to the radio is where I'd start. Then you need to check the programming whether using castle link (easiest) or by transmitter and beeps. Sounds like its in Crawler mode. Instant forward/reverse.
hotrod87 is offline
Old 02-12-2012, 10:42 AM
Thanks for all the responses. I reprogrammed again (manually) and it appears everything is correct according to the setup guide but still the same issue. How do I get it out of crawler mode manually as I don't have the castle link yet.
Kenjim is offline
