Brushless vs brushed wattage
Okay. Im looking at two setups. Both dual motor setups for an emaxx. I have one option to do two bigger brushed motors with about 309 watts per motor for 70 bucks. I can go dual brushless for like 160, and the motors will have about 378 watts each. I know that the brushless have more watts, therefore should be more powerful, and i know that the turn count and kv and voltage all affect the outcome, but will the brushless be worth the extra 90 bucks? will i notice more power simply using a brushless even with the wattage being close?
the brushed dual 700 HO's from kershaw designs
brushless, idk, i got some suggestions from diff people, looking for an amoo motor...supposed to be comparable to a feigao 7 or 8 xl...plus ill need an esc. and ill prolly end up breakin stuff. so idk. lots of money with brushless due to the fatigue on the parts. plus ill need lipo batteries to make them run nice. and thats lots of money
I assume you know you really don't need dual motors for a brushless setup - one BL motor is more than enough to fling an Emaxx around in the 40+mph range. I understand the need for bling and a dual BL setup is def a bling type setup, and overkill - unless thats what you're looking (and paying) for.
yeah, but a good BL motor has like 1000 watts or more. I'm more worried about overpowering it and snapping my driveshafts, tranny gears, differentials, and all that other cool stuff. Plus ill need lipo batteries, and the charger. So its looking like itll be really expensive. What kind of pinion gearing do most people use? I assume lower teeth b/c the BL motors spin a lot higher rpms.
Depends - motor like Neus are happy 30-37000rpm. Starting with that and working backwards to find pinion to go with a reasonable speed. SOme mess up here trying to build one for an unreasonable speed. I run a Techno Neu 1515 1Y and use a 18, but I have buggy based diffs (Ofna) and a 51 spur so that pinion is tied into the rest of the gearing.
I started with a 8XL Feigao and used 14-16 trying to keep it cool - never did, Feigaos just run hot. About your concerns- they're very real - thats what got me where mine is now - breaking stuff or reading of someone who was running what I was planning and tearing that up. Thats the downside of BL - torque is sweet, but it finds all the weakness in your drivetrain.
A dual BL setup is going to be even harder on driveline cause of the extra weight.
lol, yeah. thanks for reaffirming my fears.... but. i think im gonna go with a great planes ammo series motor(just one) from tower hobbies. has 815 watts on my current voltage. Wont need any lipos or anything for now.... ill post some vids when i get it built...
one thing thats better about a brushed motor is that it has a better drag break.
brushless motors you have to change out the rotor i think to get better
drag break
drag break
