car suddenly stop and never run
hi folks,
im new ere, and need your advice
i bought tt-01 almost a month and playing it 5x
while im playing the other day without hitting anything the car stop, i turnn off the power for a while, upon turning on the esc just blink and the servo move to the left, then the power fade. to make the story short its not responding now everytime im turning it on.
i connect the battery directly to the motor to check if its ok. and the motor respond.
in your opinion which is defective my servo or my esc?
if so can i fixed it without replacing?
whats the reason of this problem?
im using mabuchi rs 540 motor (sport tunned) and 25,55 gear ratio
thanks!
thanks!
I'd check your connection it sounds like a loose battery connector.
Also if your battery has a 'Tamiya Plug on it (big white connector)' I'd advise replacing with deans or corraly tubes avalable at your LHS. You may as well replace the plugs on the motor as well because those connectors have high resistance and are costing you horsepower.
hi folks,
thanks!
thanks!
i have one spare of battery, thats the hard part sigh!
hi to all
i know now whats wrong with my car,
i tried to run it again and it works.
accidentally it hits the ramp and its stop again
now every time it hit something it stop.
so the problem is the power connector or battery,
i will try to replace with the dean connectors
i hope it will solve the prob.
Is the motor the same age as the car, or older?
If it's older it may need cleaning out, or replacing if it's in a very bad way.
I wouldnt want to say it is definately the motor, but it might be one of the brushes sticking
If not, then as said it may be a connector, esc or reciever issue.
problem solved
i sell my defective car and i bought a new car
buggy but still ep.
much more fun i have
buggy but still ep.
cranky
you need to check in you reciver where your ariel goes to make sure your chi[p has not come out this happend to me when i crashed. but mine was probly worse than yours but check in there and see if that solves the problem.
advise on cleaning car
since i have had my car i have neaver cleaned it at all i have had i 5 years but onli used it 2 years solid so far i ahve had to do alot of work to keep it fireing evertime i pull start it. as i am into engins i understand how things work but is there any need to keep parts and componets clean? as im wining people on my street in races but it has grass all over it and round drive shafts
