Futaba 7PX
#739
or Hyperion: https://hyperion-world.com/en/charge...080mah-lifepo4
#740
Inductive charging system question: I recently picked up the charging system for my 7PXR, it worked great the first time when charging the radio with no issue. Pulled the radio off the charger and ran for 20mins... came back and the LED on the base unit is no long coming on when plugged in?
#741
Scoured Google and this site and can't find the answer to this one: Anybody know what size & pitch the screw at the center of the wheel is? I know it is a 2.5mm screw head but can't find anything else on it. Thanks in advance!
#742
Then it will probably be an M2.5 screw, or M2.6
#743
hmmm, Ok. That gives me something to search on. Thank you Roelof!
#745
On my new 7pxr it's definitely not a standard m3 screw. The threads are a different pitch. It looks like a tapping screw as it tapers a bit at the tip of screw.
I appreciate the input, thank you.
Last edited by cartmen34; 02-19-2021 at 08:35 PM. Reason: words are hard. sometimes.
#748
What options are there for a telemetry sensor for nitro engine temp? Do any other sensors other than Futaba work? And are there any guides out there on how to mount the sensor to the head of the engine?
#750
Hard Case: ProTek RC Universal Radio Case (No Insert)
Soft Case: ProTek RC Soft Case Universal Transmitter Utility Bag
Insert: ProTek RC Universal Radio Case Insert (Futaba 7PX and 4PM)
One of the great things about the ProTek case is that there are quite a few Tx inserts available (surface & air), as well as a 3-layer "pick & pluck" (2 layers usable) insert, which you can configure for whatever you want (batteries, cables, other accessories, etc).
