Futaba 7PX
#392
Got my Tx updated to 4.0.
Anyone having issues updating the Rx? When I go through the process of prepping the Rx for the update. I hold down the link button give power, and after the red light blinks once release and press again for a red/green flash. I get an amber light instead of the red/green flash.
Anyone having this issue or are yalls Rx's updating with no issue?
-Jon
-Jon
Mine updated (both tx and rx) without issue. How are you updating the rx? (ie. through tx or usb adaptor and pc)
Leonard.
#394
Tech Legend
is this the proper place to get the software updates?
https://www.futabarc.com/software-updates.html
Reason I ask is that the link for 7PX says it was updated in Nov 2017?
#396
#399
I have the T7XC with version 2.3e
Looking at the updates it seems it is only needed for more SBUS functions like remote programming of the 970 ESC and other SBUS devices. When using normal servo's it looks to me there is no need to upgrade.
#400
Tech Legend
not sure if this is common, but when going from the default 50 / 50 split (forward and brake) to 70 / 30 split, I notice the applicable channel on the main screen has it filled somein one direction. Is that common or is this something I need to change on the radio. Doesn't appear to affect anything.
#401
I have read through this entire forum and have seen the question asked a couple of times about the ability to copy model data from my 4px to an SD card then load the model data onto my 7px but never did see a definitive answer. Can someone let me know if this is possible or if I will have to set up every one of my cars manually on the 7px? Thanks everyone.
#402
#403
Anyone using the standard HT5F1800B NiMh battery pack?
As it is listed to fit my T7XC it does not fit....... I wonder if the 7PX has the same issue.
The battery is 84mm long but a small notch on one side gives only room up to 79mm, I had to cut away that small notch.
#405
The Futaba NiMh pack is made from 4/5A cells. not very common.......
