Hobbywing XERUN XR8 Plus
#721
Honestly I wish the timing controller was adjustable and fixed. There is no simple way to dial in x * timing on an XR8 and there really should be.
#722
Hi, Im having a problem with the xr8 pro g2. It is brand new. The problem Im having, is that when I come down the straight and then turn, there is almost no power when I get back on the throttle. Below is what is written in the manual, and it is exactly what is happening, the rest of the track its fine. I started with the 1/8th off-road setting( I didn't check if it works properly on the stock setting), then I adjusted things from there.
5D: Turbo Decrease Rate (deg/0.1sec):After the Turbo Timing is activated and the trigger condition turns to not be met (i.e. vehicle slows down at the end of the straightaway and gets into a corner, full-throttle turns to partial throttle, the trigger condition for Turbo Timing turns to be not met), if you disable all the Turbo Timing in a moment, an obvious slow-down like braking will be felt and cause the control of the vehicle to become bad. If the ESC can disable the Turbo Timing at some “speed”, the slow-down will be linear and the control will be improved.
#723
my local supplier in europe just told me that apparently the Xerun XR8 pro g2 is not available anymore (and the SCT but thats clear)- only the Xerun XR8 plus g2s . Do you guys know anything else about it? I mean the xr8 pro g2 was released in 2021- why would HW discontinue it already? I rather thought its a supply chain issue, since no one here in europa has it in stock!
#724
You can also look at the website for the TTM Funktionsmodellbau e.k store here.
https://www.ttm-shop.de/katalog/search?do=hobbywing
If you go to the Hobbywing website then there is an XR8 Pro G2
https://www.hobbywing.com/goods.php?....0.0.0.0.0.0.0
I hope this helps you in your search for the esc you want.
#725
XR8 Pro
My friend brought me an XR8 Pro to look at as the switch needed replacing. Once I replaced the switch we noticed the fan wasn't working properly and the receiver released its magic smoke.... i measured output voltages for fan and receiver and noticed that they were 16V, the fans and receiver are rated at 6-8V so I know that this can't be right. Without a circuit diagram it's difficult to diagnose the issue, I was just wondering if anyone here has had a similar issue?
Andy
Andy
#726
Xr8 plus g2s
Anyone have any tune set ups for the xr8 plus g2s ?
cheers
cheers
#727
Anyone else have overheating issues with the g2s plus? Edit- my Hw motor just so happened to go bad right after the new esc and that’s the issue.
#728
My Son down loaded a team Hobbywing set-up sheet which gives all sorts of information. Call it up and print it. Hope it helps you guys.
