Speed passion V3 / V3 MM / V4 36mm motors, HELP!
Speed passion V3 / V3 MM / V4 36mm motors help!
V3
V3 MMM
V4
I would like to know...this thing...is is a error of marketing...
I have the 5.5T v3 motor that as 7000kv and 65amps
And i want to change to a lower kv motor that use less amps for runtime....
But watching the table of the later MMM V3 the 5.5T motor is 6100kv and the amps are 48AMPS... this must be an error, right? I see Amainhobbies with the same specs to sell but they use the Speed Passion spcecs...
And the new V4 motors do not show the amps rates...that is bad and wrong marketing...we need to know those specs!
As for the SKYRC Motors and Hobbywing motores they share the same specs...
-SKYRC & Hobbywing V10
Being a 5.5T motor a 6450kv and 100amps....
It can't be right those 48amps of the 5.5T v3 MMM Speed Passion, right?
V3
V3 MMM
V4
So ...48 amps for a 5.5T motor?
Not real right?
What is the mail for contact Speed Passion? I cant see any on their website...
Not real right?
That does seem strange that the V3 would be more powerful than the MMM versions. It seems to only be those 4.5 and 5.5 motors. The rest are as you would expect with the MMM on top.
Here's their global email address for customer support: [email protected]
