iCharger 406 DUO Charger
#46
So I am looking to get a 10awg charge lead with low IR. I tried to do some 40amp charging/discharging last night with my 12awg leads and the wires got up to around 115 deg. My iron wont do a 10awg connection well, so I am just looking to pre purchase one. I would prefer one that is configured for 2s, because I never change anything else.
Also, just a question about how to do it better. I had a 2mm bullet that needed replacement on my current charge leads. So I used flux to prep the wire and the new 2mm bullet. I tinned both with 60/40 solder, heated both at the same time with my iron to get a good flow. But afterwards, I noticed that my IR on my packs doubled. I assume this number is because my solder job/bullet are trash. Obviously, my packs didnt really double in IR. Every time i have used a factory built lead, the IR calculation yields more consistent and probably more accurate numbers. Could it be the lead free solder they use? I kinda wonder if my solder is not as good as it should be or if its just my technique.
#47
#49
Just picked up a 406 and im searching out a power supply. I only charge 2s packs at 10amps max. Could this power supply provide enough power to charge 2ea. 2s lipos at 10amps on each channel? The amps look high enough and 900 watts should be good,correct?
http://www.ebay.com/itm/201057840167...84.m1423.l2649
#50
With this power supply, you can charge 2S lipos to the maximun power of the 406 each channel together.
900W/2 = 450 W for each channel power.
450W/8,40 volt (2S lipo's) = 53A.
Limit of the 408=40A each channel.
#51
#52
But yeah, it will easily handle elex's stated needs, even the 20 amps per side I think he's saying (2ea. 2s lipos at 10amps on each channel).
#54
10x8.4(full voltage) = 84watts.
84 watts x 2 = 168 watts of power needed. Add about 20% overhead for giggles and anything 200 watts and higher will work
#55
You've got the hardware. Push it! 40a baby
#56
Just got this charger. Very nice
#58
my PSU is 75amp 12v and 117v ac. But.....I just realized my charger can only do a 15amp 4s charge at 12v. Or about 252 watts, lol. In order to get the full 500 rated watts....you need 24v. I would like to stick with 12v. I see the power labs will do 404 watts at 12v. I am curious what this one does. I could not find the specs in the online manual.
#60
SMH...
Input voltage range: 10-30V DC
Input current limit: Total = 60A, Ch1/2 = 47A
Maximum charge power: 1400W at >23.5V (1000W max. per channel)
Charge current range: 0.05-40.0A per channel, or up to 70A in synchronous mode
Discharge power: 80W per channel, or up to 140W in synchronous mode
Maximum regenerative discharge: 1000W per channel, or up to 1400W in synchronous mode
Current drain for balancing: 1.2A per channel, or up to 2.4A in synchronous mode
USB charging port: 5V/1A current limiting protection 1.2A
Balance accuracy: 10mV
LiPo/LiIo/LiFe: 1-6 series per channel
NiCd/NiMH battery cell count: 1-25 series per channel
Pb battery cell count: 1-18 series per channel
PC Connectivity: USB port
Weight: 910g
Dimensions (LxWxD): 171x118x59 mm
Warranty: 1 year
