question about sanwa super vortex zero
#77
We'll, ran this thing and I got to say, I'm impressed, I've run takin, Orion, lrp, it hangs with them all. The ability to program from the driver stand to the 1% is a nice feature, the braking is too good, had to dial it out, no noticeable latency with the with the telemetry.
All speedos should have some sort of functionality that sends telemetry data. If only to your smart phone
#80
Any other opinions of the esc?
#81
Not sure whether to go for this or wait for the new model flow team works, i too wondered if it was manufactured by another?
#82
Which online stores are stocking these Sanwa Super Vortex ESC's plus the MT-4S Tx/Rx?
I found my answer just reading more threads..
Hobby People has the Super Vortex with Rx 472 combo for $269.
And the MT4S for $299.
My credit card might throw up.
#83
Hi can I check with fellow users if this esc supports counter clock wise motor rotation?
#85
Hi. I have done the transmitter calibration. But I cant get to the Setup Mode 1 to 4 which is on the ESC itself. After I ON the ESC, a solid green & blinking blue will be seen. No matter how long I kept pressing the Setup button (At the On/Off ESC switch), the most I saw is the green will turn blinking & blue still blinking, cant get the red light. Current Connections to 472 are Gyro to CH1, Motor fan to CH3, Vor Zero to BATT. Pls advice.
#86
Make sure that your radio is off while performing the steps below.
#87
Thks fb2402. Got it done. I have another question. On the M12 telemetry display, I can see Temp1 showing @35c but there is no reading on Temp2 (just show -----), is it normal?
#89
Hi. Does it means all sensor brushless motors have temp sensor built-in? Checked online, most motor manufacture data did not indicate any built-in temp sensor. Abt the 6-pins sensor cable, is blue color the one related to motor temp? Currently I am using a sensor motor. If only certain motors have this built-in temp sensor, can recommend which brand/model?
#90
http://www.amain.com/product_info.ph...ess-Motor-105T
Update: The Reedy Sonic Mach motors does not have a built in temp sensor. At least is not indicating any through the telemetry.
