ORCA Team - VRITRA VX COMPETITON ESC
#991
just received my vx3. Can some one explain to me why it looks like a reshelled speedpassion reventon?
hope it works better then a SP :S
#994
software / apple
hi
i have just bought the Virtra VX3 speedo along with the programming card my question is will i also need the usb link cable to update the card.
also i have a mac book and was wondering if the software will work on this or just a windows based pc.
i will be getting the 13.5 motor to so was wondering on a good starting point mainly in blinky
thanks
andrew
thanks
andrew
#995
Team EAM
hi
thanks
andrew
thanks
andrew
No it will not work with Mac based computers unless you are running windows in Parallel or boot camp.
For speedo settings I never change from this for spec.
PWM 4k
Punch 10
BPWM 2K
Initial brake 10
drag brake 5
EA
#996
You only need the USB to update the software and right now there is no new software for the VX3. Only what comes on it.
PWM 4k
Punch 10
BPWM 2K
Initial brake 10
drag brake 5
EA
PWM 4k
Punch 10
BPWM 2K
Initial brake 10
drag brake 5
EA
#998
Another Q.
I am trying to setup my VXX (4.1) Mod profile to manual recommended settings for the TX 17.5 but some of the parameters don`t have the range depicted in the manual. Such as recommended timing range is 27-36 but the max on my programer shows 30.
Is the manual written based on a different Firm Ware, if so how do the values correlate?
#999
Nevermind, to answer my own question I was trying to setup a Mod profile with Stock recommended settings. Switched to Stock mode and all is as shown in manual.
Is there any gain to be had running a 17.5 in Mod mode?
#1000
#1001
I've been playing around with a motor analyser and I'll tell you right now, all the motors from the same manufacturers are different in relation to the end bell marks. They are more of a ballpark. But the slightest little difference in timing makes em really sing. I know it's not the answer you're looking for, but unfortunately it's true.
#1002
#1003
This is an attempt to post what I received from EA this evening. Doubt the pictures will show as they do when I received it in MS Word. Still should be helpful though.
Bill
How to use ORCA USB adaptor to update your Electronic Speed Controller (ESC)
This applies to the following hardware:
Vritra VX (all colors)
Vritra VX1 (all colors)
Vritra VXX (all colors)
“USB ready” Program Card
What you need:
- An ORCA USB Link Adaptor
- A Windows PC with one of the following Operating Systems:
o Windows XP (all versions)
o Windows 7 (all versions)
o Windows 8.1 (non RT)
- Sensor cable
- ESC to be updated
- Program Card to be updated
Note: Be very careful when disconnecting the Program Card adaptor from the USB Adaptor. It is recommended that you do not pull by the wires and always pry at the plastic connections to prevent damage.
STEP1: PREPARE YOUR SYSTEM
Windows 8.0
You must update to Windows 8.1 then follow Windows 8.1 procedure
Windows 8.1
You must disable Driver Signature Verification.
Follow this link for step-by-step instructions:
http://www.howtogeek.com/167723/how-...igned-drivers/
Then proceed to All OS procedure
All OS
You need winrar to uncompress the installation files, it can be downloaded here:
http://rarlabs.com/download.htm Select either 32bit or 64bit to match your OS. (Note: Suggest using WinRAR version 5.01 files as opposed to the Beta files at the top of the list. Bill)
Save your ESC settings before proceeding to the next step as it will be erased.
That's it!
Bill
Bill
What you need:
- Sensor cable
- ESC to be updated
Windows 8.0
Windows 8.1
All OS
That's it!
Bill
Jon
#1004
polarity chamge
hi
I see in the setting up of the VX3 that I can change the polarity of the motor wires I take it that when doing this that the + and the - and the change is between the A and the C
#1005
