Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 02-18-2013, 05:38 AM   #226
TryHard's Avatar
Originally Posted by SerpentCT4S View Post
Hey, hopefully you guys can help me.
I ordered and received a Hobbywing Xerun v2.1 120a 10.5t combo.
http://www.falconsekido.com/products/xerun-combo-x60
I started to get it ready for my car. I got everything soldered. I then set my neutral, full throttle and full brake. I thne tried to connect it to my program box, but it doesnt do anything. All it says in connecting ESC. That didn't work, so I tried to tune it by connecting to my PC, and that didn't work.
Can someone please help me out. I have tried every possible way to connect it with no luck. I plan on calling Hobbywing North America tomorrow.
Deffiently check the plug connection on the box. Also, you might want to check what version of the program box software you have.
Old 02-18-2013, 07:06 AM   #227
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
Originally Posted by lewis110 View Post
Make sure you are using the receiver wire thats plugged into the center port of the program box. Also when plugged in the metal tabs you can see on the plug should be facing up towards the screen.
What are you putting it in? If its a 1 cell car, you have to plug a 2 cell battery into the esc in order to use the program box.
Hope this helps
Roger
My tabs are facing the right way.
I am putting the system in my 1/10 drift car. I usually run a 2s lipo in the car. I'm not sure what you mean by a 1 cell car.
SerpentCT4S is offline   Reply With Quote
Old 02-18-2013, 07:07 AM   #228
I will take a look at the plug.
How can I check what version my program box software is?
Old 02-18-2013, 07:42 PM   #229
lewis110's Avatar
1 cell car is a pan can that uses a 1s (1 cell) battery.
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 02-19-2013, 02:54 AM   #230
TryHard's Avatar
Plug it into your PC, and open the software, but on the menu bar, under Devices, put it to 'LCD program box'.
Old 02-19-2013, 03:42 PM   #231
I have a 1s in no timing mode with the program box working also in no timing. I also have a v3 how can i get the box to work with both of them in no timing mode?
Huskerfan1212 is offline   Reply With Quote
Old 02-19-2013, 07:09 PM   #232
My esc doesn't work anymore and Hobby Wing customer service is terrible.
What other sensored esc can I use in a drift car?
Old 02-19-2013, 07:36 PM   #233
lewis110's Avatar
www.falconsekido.com you have to get the new 3in1 program box if you want to use the same box for both the 1s and V3. It cost 24.99 but if you have both esc's its a great investment. Also comes with a nice battery checker.
Old 02-19-2013, 07:38 PM   #234
lewis110's Avatar
Who did you buy it through?
Old 02-20-2013, 04:58 AM   #235
Shore its mot the shop letting you down Also what went wrong and how
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 02-20-2013, 06:06 AM   #236
Idk how that slipped past me. I had no idea about the new box.
Old 02-20-2013, 02:24 PM   #237
I bought the combo. Motor, ESC, program box
Hobby Wing North America
Old 03-05-2013, 01:13 AM   #238
onekiwi's Avatar
Whats the differences between the V3/V3.1 and V3.2?
Anyone come from an R10? Notice any differences?
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 03-05-2013, 04:55 AM   #239
lewis110's Avatar
There is only a V3 and V3.1 the V3.2 is the pc software.
The only difference between the V3 and V3.1 are a few little updates. The V3.1 comes with an all alum case. The V3 just had an upper alum and plastic lower half. The 3.1 also has the fan raised up off the heatsink 1mm for better airflow and increased cooling. The V3.1 has rubber seals around the programing and sensor ports to help keep dust out of the speedo. They both use the same firmware. I just recently switched a couple of my cars over to the V3 coming from a 2.1. The esc is a lot more adjustable and it has a great feel to it.
Hope that helps
Roger
Old 03-05-2013, 10:42 AM   #240
Hope that helps
Roger
My V3 esc`s also has the outer heatsink corners raised just like my V3.1.
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
