Tekin rs inop after 212 update?????
Ok so I was running at test and tune today all working great then found out that we have to have speedo in blinky mode for my class so we hooked esc up to track computer via hotwire performed update to 212 software , hooked up to rx, powered on, calibrate throttle, NOTHING all LEDs function fine it is in blinky mode, shows neutral brake throttle everything works except the motor lol....also no tones during initializing when turned on. Tried to reset same thing, tried new sensor harness and motor same thing, all looks normal no fault LEDs just won't go any help here please I am afraid to do my rs pro and have the same thing happen...... HELP
R/C Tech Elite Member
it worked then you loaded then it didn't. check your receiver plug you might have plugged it in backwards.
reload 212 off the tekin site.
press both buttons at the same time to re set the speed control. if all else fails call tekin and send it in to get fixed. there service is great.
Good luck
Good luck
hey im having the same problem how did you fix it?
I would try it with a 2s LiFe receiver pack, I've never had good luck with boosters. Also make sure to check the 1s box in the HotWire.
