Deans Connectors?
Deans Connectors?
I am switching everything I have over to Deans connectors. Is there a standard way of installing them? Most of the used stuff I have has the female connector on the battery and the male on the ESC/charger. is this the normal or accepted way of doing it? Are the Deans an upgrade over Traxxas connectors?
-Joe
-Joe
Super Moderator
Trader Rating: 31 (100%+)
Always use a female connector on the battery. Male plugs normally have the contacts exposed which could result in a short (bad thing), so yes it's normal. Deans vs. Traxxas, it's all about preference really both work just as well.
-Joe
Also it is commonly accepted that you wire the positive wire to the vertical post when the connector is oriented so that both the posts side by side.
At least that's how all my batteries that had Deans on them have come.
If you need a photo I can get you one.
Star
Star
Super Moderator
correct, if you look close a "real" Deans will have a + sign on the positive side. I'm not sure if the China knock off plugs have this or not.
Deans certainly are the most popular. They make a real solid connection that lasts a long time. Electrical resistance is extremely low, giving the connector excellent performance.
Tamiya connector are low quality and make very poor, high resistance connections.
Bullets are great for ESC to Motor connections. Some racers use hard pack batteries with only bullet connectors.
TRX connectors are rated the same as Deans plugs. Unless space is at a premium, I'd use the TRX connectors. Much easier to take apart, but I find a little more difficult to solder.
OK guys thanks for all the responses, it is appreciated. If someone has a pic to share just so I know for sure that would be great, otherwise I think I have it figured out.
-Joe
-Joe
Super Moderator
might not help but it does show that the pos. is on the vertical tab..
http://www3.towerhobbies.com/cgi-bin...?&I=LXNCU4&P=M
