My m8 beeps
Super Moderator
My m8 beeps
everytime I set my m8 down it beeps.
Cries for attention?
ur battery connection is less than perfect, its losing voltage for that instant and shuttin on and off. check ur connection from the tray to the radio and ur batts/charge jack in the tray.
R
R
Super Moderator
hey thanks I'll check that out, could explain why my spektrum was cutting in and out.
Super Moderator
how do you fix this problem?
M8
I have 4 m8 radios And they all have had issues with the battery becoming disconnected at the slightest bump . To fix this i use a piece of foam or rolled up paper towel in between the battery cover and the battery carrier. If it beeps more than once your battery is low.
