Radiomaster MT12
#61
Another baseless comment made based on your feelings. You don't know me or what I have or haven't done in my life or what I am or am not capable of or my work experience or my training/education, so keep that in mind when you reply to my comments. FYI, other than all the fad classes there are only a couple things in surface I haven't raced, Boats, 1/8th scale buggy and Stadium Truck. I'm a pretty experienced racer.
How much experience do you have with open source? Are you a programmer or an electrical engineer? For the record I am not, but have worked closely with people with that skill set and have seen them first hand do some really crazy and amazing things. I've seen them move mountains. I will put it to you this way, I was a contractor for google X, so I've seen some stuff, the studio I worked at blew peoples minds, people came to us. Some of the tech I was around a decade ago is just starting to reach the masses. Anyone who works at google can confirm that what they are doing behind closed doors is super advanced and most of what google does will never be seen by the public. google encourages it's employees to play, experiment, and to push the envelope and they give you the money to do so if you are staff.
You're right I haven't, but I have raced 1/12th scale stock and watched the mod guys, so I am very familiar with the speed of a 1/12th scale mod. A drone is much faster.
Both of you are still not taking into account how advanced micro cameras are and like I said, maybe today it's a struggle to race an RC at speed around a track using FPV, but I promise the tech used in cell phone cameras (image stabilization) will be available for RC cameras in the very near future making racing a surface RC using FPV a breeze. Also the FPV example given is a horrible one. I clearly stated that the camera needs to be mounted properly and mounting it behind lexan is not going to do the camera any favors and WILL make visibility very difficult.
The drone I was watching at the airfield was flying in a very tight space, a much tighter space than a surface RC track and was easily twice as fast as any surface RC I've seen on a track. Zero issues. Yes the drone didn't have barriers on either side, but a skilled pilot has zero problems maintaining a tight and precise line. If virtual lines were painted in, the drone pilot would have zero problems staying within the lines.
Clearly you've not driven 12th scale mod.
https://www.youtube.com/watch?v=Yt5J3BjGQe8
#62
Simple fact is: no programming in the world will make a battery suddenly supply more voltage to the ESC than it can physically provide. It's physics, not magic and there are hard limits.
#64
I'll wait for someone with actual experience with EdgeTX to chime in before I let this rest, because there are too many naysayers on this forum who do not think outside the box and most people here have zero experience with EdgeTX and their replys are based and rooted in what they currently know, not what may be possible.
#65
Wait, now it's the ESC that is supposed to do it? That is technically possible (although neither really feasible nor legal). But you're claiming that only some clever programmer has to play with code in the radio and it will happen. And that is impossible.
#66
Are you an electrical engineer or a programmer? Have you worked with people with said skill set that are capable of making what you think is impossible possible? How much experience do you have with EdgeTX?
#67
I can assure you with 100% certainty that you cannot give the ESC more voltage by pressing a button on the radio.
#68
None.
Yes.
Yes.
Yes, to a point. Reverse engineered the programming interface so I can download telemetry. That's on a physically different plug though, can't do it by the radio signal lead.
Take a step back for a moment and consider the reverse: why would a manufacturer build a race legal ESC intended to beat the competition but intentionally slow it down? They perform at their best at all times, with the minor caveat that there are some reprogrammable settings like drive frequency et al that can tune the feel. Changing those on the fly won't be enough to give you push to pass, the only thing that might is a boost in timing, but changing timing is explicitly illegal in blinky. If you're running mod, you'd have it give you that timing at all times, not just when you push a button on the radio.
This isn't about what EdgeTX is capable of. This is about what ESCs are capable of. You're claiming that an EdgeTX expert can fundamentally change the capabilities of an ESC. They. Can. Not.
Yes.
Yes.
#69
Mod delete please
#70
I raced with it, and for me, it will not be replacing my Flysky NB4. I'll probably make a video explaining my reasoning at some point, but I'm having a hard time not sounding too negative. As a nerd who is into all sorts of RC, I like the MT12, but it isn't the radio for me for racing.
You can check out my MT12 videos and I'm making more as I see more people asking questions about setting up EdgeTX.
I noticed you were comparing to other RTR type receivers and air receivers - do you have access to the 'flagship' low latency radios, the surface Futaba/Sanwa options? I was curious about their performance.
Also, I gather the Radiomaster has a 1000Hz mode on ELRS - have you tried latency measurement on that setting? I think you tested on 333Hz.
I'd love to hear your feedback on why you won't be racing with it. In the aircraft side of OpenTX/EdgeTX, it took a few years for Radiomaster to establish themselves as the 'manufacturer that listens' after FrSky went closed-system and Jumper technical team left to start Radiomaster. If it's an ergonomic thing with the MT12, I fully expect Radiomaster to do what they do with the air radios - offer upgrades, modular ones. Colour screen will likely be coming, CNC machined parts, plastics fit and finish. Hopefully some trigger and wheel position stuff.
#71
Thank you for the reply and confirmation. People are stating that you cannot program the transmitter to send more voltage to the ESC via a programmed button so that you can activate a push to pass (sending more voltage to the ESC) if the ESC is not capable of this feature. Can you shed some light on this?
There is a guy in France who seems to have mastered programming open source and looks at packets sent and received and I assume a bunch of other things when creating a program(?), so it appears to me that if one knows the ins and outs of how things work they can make it do anything, even if it wasn't made to do what it is your trying to make it do.
Thank you for the offer to help with set up. I'm just getting my feet wet and reading about EdgeTX. I just learned about Radiomaster after I purchased a V761 Spitfire and the setup video I watched to bind the V761 to the Radiomaster made basic setup look super simple. The TX12 MKII is my next radio purchase (I like smaller radios and that price is unbeatable, I was looking at a Spektrum 6ch before I discovered Radiomaster).
I'm pretty amped on flying right now, better attitudes, forward thinkers, people at the field are super cool and welcoming, they are easy to approach, they encourage you, and they are more than willing to help to get a new flyer going, and it's so much cheaper than surface RC and I don't have to pay a fee to fly my plane at the field (if I stick with it, I will do my part and contribute somehow).
About the push 2 pass. The battery can only supply a certain amount of volts. It can’t be increased with the push of a button. That said, there are other ways to get a burst of power with the push of a button. I will list a couple of them. One way is to change the timing of the esc with the push of a button, which can be possible with the right programming. Blheli32 esc’s can probably do it if programmed. And now we have opensource Am32 esc’s which can be programmed to work for rc cars. Another way is with a power booster device that has a bunch of capacitors in it. It is connected between the esc and battery and the pwm cable connects to any open channel on the receiver. There are a few companies that make these. One of them being Turnigy. Search for Turnigy Enos In-Line Power Booster.
#72
You’re welcome. Anytime.
#73
I have my MT12 for a week now, and bought for and use it on my crawler.
This things allow me the usual stuff that any radio can do, given enough channels. Such as movement, lights, winches, overdrive and dig.
But EdgeTX allows me to create mixes such as how I'm handling my winch.
It has a normal in/out on Trim 4, but I can also control it with my throttle in either self or helper mode.
Where 'self' is winching in and slowly moving forward on throtle, and 'helper' is winching in and moving backward. While having a wav file notifying what mode I'm in. (Oh and leds showing it as well.)
I can also have my winch locked, so I can't accidentily turn it on, while I'm trying to keep my own balance on some muddy incline.
That's the BIG thing about Edge/OpenTX: If you can think of it, you can program it. For mixes like my own, it has a crazy learning curve though, don't underestimate that.
What I DO consider an issue with the MT12 is a lack of real switches. Yes, you can use a trim switch as a switch, to control channels, but it's a lot of work.Also the two extra switches you can put on the base are seen by the radio as a pot, so you cannot assign that directly as a condition to turn a mix on or off. (You can work around that with Logical switches, which I've done).
EDIT: You need to setup the additional switches in the hardware menu. (As per the manual...)
For racing I don't really see the point. Also not sure what a race directors opinion is going to be when you show up with an ELRS protocol radio
Edit: Oh, and forgot to mention: You can't use Companion for it yet. That is planned for the next release of EdgeTX. 2.10, we're currently at 2.9
#74
gigaplex Thank you very much for your replies and the information you provided. I apologize for being confrontational. Now that I know your level of expertise I know that I can trust what's posted by you and again I apologize. I hope you can understand where I was coming from.
There is too much misinformation on the internet and unfortunately there are a lot of people here that draw conclusions based off of their feelings while disregarding at times factual information. This radio can be very simple or incredibly complex and when it comes to things of complexity I like to know that I am getting my information from an expert so that I can not only educate myself, but get the truth from someone who actually knows.
ELRS Thank you for the reply and information you provided.
#75
