Futaba T4PM 2.4GHz radio system >
Like Tree13Likes
Old 04-19-2019, 05:07 PM
  #31
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Well that may be a good thing, speaking to the 4PM's capabilities!
1/8 IC Fan is offline
Old 05-07-2019, 08:25 AM
  #32
What are the most reasonably priced receivers for this radio with 2channels
Mattdaddy1974 is offline
Old 05-07-2019, 04:24 PM
  #33
1/8 IC Fan's Avatar
R304SB is not bad, you can find them for around 60$
The Futaba R204GFE S-FHSS is available too for arround 50$
the HobbyStar HFS04C is available too but as a S-FHSS system, which should work too, for around 50$
The days of only a 2 channel receiver are pretty much coming to an end, unless its an AM or FM radio.
Old 05-07-2019, 07:50 PM
  #34
I guess hoping for a $30 rx was wishful thinking. The tax feels a lot better than my Spektrum.
Old 05-07-2019, 08:01 PM
  #35
1/8 IC Fan's Avatar
You may look through the For Sale threads, there may be a bargain on there as well.
Old 05-07-2019, 10:55 PM
  #36
Roelof's Avatar
S-FHSS receivers can be found for arround 30-35 dollar, the Orange brand can even be founf for just 20 dollar
FUTABA S-FHSS compatible receiver_Receiver_POWERSTAR
https://hobbyking.com/nl_nl/orangerx...-and-sbus.html
Futaba R202GF S-FHSS 2.4GHz 2 Channel Receiver #R202GF,
Futaba R203GF 3-Channel 2.4GHz S-FHSS Receiver #R203GF,
Roelof is offline
Old 06-04-2019, 04:00 AM
  #37
Anyone who has seen/used this IRL?
Doubting between this and a Sanwa MT-44
Uses: 1/8 ebuggy, in the future 1 more class (1/10 2wd buggy probably).
Important:
- Build quality (plastics) and 'feel'
- Physical adjustability of the trigger and wheel. I know the Sanwa can slide the trigger 5mm front/back, how much is this in Futaba systems? How well adjustable is the spring tension etc.
I already read the manual, and I like the fact you can adjust the 'range of motion' of the brake movement in the T4PM.
How large is the total trigger 'range of motion' (full throttle to full brake) of Futaba compared to Sanwa?
I take it both Futaba and Sanwa can adjust throttle curve etc
- Reliability / warranty ( I hope to never use this, but still). Located in Europe btw.
Somewhat important:
- Speed (with normal servos), but I think the difference with Sanwa shouldn't be noticeable?
- Battery life
Not/less important:
- weight: it won't be a huge difference anyway
Yes I know, 'go to a local hobby shop and try them both'. I'm planning on that
vsral is offline
Old 06-29-2019, 08:38 AM
  #38
Well the 4PV is off A Main's site and also off of Futaba USA. If this radio is said to be better any thoughts why it's less expensive with the same non SR receiver? I know earlier it was was said that this unit is better then the 4PV but if you are not going to use the SR receiver with Futaba SR servos are there more things? The reason I ask, just ordered a 4PV, can send it back no problem and order the 4PM... figure it would be better to have a newer model.
RCJamesJ is offline
Old 06-29-2019, 09:33 AM
  #39
I also got myself a (used) 4pv.
One difference I've been told is that there isn't any option for a dropdown or angle adapter on the 4pm.
vsral is offline
Old 07-18-2019, 09:04 PM
  #40
Originally Posted by fazznick
I see that the 4pm takes 3 aa batteries and operates at 4.5 volts. Does this mean that a 1s Lipo is going to be the only option for a battery pack?
Nevermind: downloaded the manual and figured it out
I couldn't figure it out from the manual. I can see what model batteries Futaba wants you to buy. But I see this 1S pack that says it is compatible with the 4PM, but I can't see anywhere in the manual that states a 3.7V pack can work. Can you let me know what you figured out? Thanks.
CaptainOne is offline
Old 07-21-2019, 04:45 PM
  #41
TurnNBurn's Avatar
Hi all - I ‘ve been considering getting this radio, since it appears to be the new “step down” from the 7PX, which as nice as it is, is over my budget. I was looking at the 304 but noticed in Tower Hobbies’ information that it’snot Intended for use in Nitro vehicles? Is the 334 the only T-HFSS receiver that’s Nitro safe? Also, is the 334 also the only one with a shorty antenna?!
Sorry for the noob questions - just getting back into the hobby after a LONNNNG time... Let’s just say that my 3PJS probably wouldn’t cut it anymore.
TurnNBurn is offline
Old 07-21-2019, 09:30 PM
  #42
Trader Rating: 36 (100%+)
Telemetry recievers are r304sb, r314sb r324sbs and r334sbs
Antenna less Telemetry receivers for electric only cars are r304sb-e, r314sb-e and r334sbs-e
riceball777 is offline
Old 07-21-2019, 11:14 PM
  #43
Roelof's Avatar
It has nothing to do with nitro but with the size of the track.
The so called antenna less receivers have a small antenna in the receiver and so close to the carbon and metals of the chassis, this will cause a less receiver signal. To be sure you will have enough range the receivers with an antenna wire will be the best although many people using antenna less receivers did not face issues on larger tracks
Timmanis2000 likes this.
Roelof is offline
Old 07-22-2019, 07:52 PM
  #44
TurnNBurn's Avatar
Thanks for the info guys.
Old 07-22-2019, 08:30 PM
  #45
racknpinion's Avatar
The r334sbs has dual antennas, just FYI.
Motorman007 likes this.
racknpinion is offline
