having trouble with driveshafts on kyosho evolva m3
Hi people I'm having trouble with driveshafts on kyosho evolva m3 there too loose is there anyway of making the shafts less loose.Its only loose when I turn the wheels but I've been told the driveshafts need to be a little loose .If anyone knows how I can fix my problem I would appresiate it.
The driveshafts need side to side play so they don't bind. If your track width is set correctly (use the Kyosho set ups for an idea on these), you'll be fine.
If you're really talking about universals, you need to shim the axles so they have minimal side play.
