Do I have an air leak? Baja 5b
Hey guys,
I have over 10 years of nitro experience and about 5 minutes of gas. My baja has the 23cc fuelie and a DDM V2 pipe. I'm the second owner.
The motor fires right up on the 1st or 2nd pull. Idles nice for about 30 sec. Then the RPM's go up...up....UP...UP... and it stalls out.
The throttle linkage never moves when this happens so I would assume air has to be entering from somewhere. Any thoughts?
This can also be the opposite of leacking - vacuum! Check that the tank gets to vent, it sounds a bit like it doesn't, and therefore it is not able to pick up fuel.
Making progress. I didn't get to drive it tonight but I was able to reset the needles. It wouldn't fire up after I set them to factory but a few tweaks of the LS needle and it fired up. I'm surprised at how much it responds to the LS adjustments. 1/16 of a turn goes a long way. I can now let it idle for 2-3 minutes with no issue.
I'll let you know once I can open it up and get the temps up.
