Kraken RC Bullet Fueler For HPI Baja 5B 5T 5SC Large Scale Fueling System
You will never fuel your Baja the same way again!
After 3 prototypes and a full year's of R&D, we are super excited to release this to the Baja Community! The "Bullet Fueler" is the first ever true large scale RC fueling system for the HPI Baja. It is both lightweight and tough! It's constructed with billet aluminum and proprietary blend of high impact gas resistant polymer. It is sealed with replaceable Milt-Spec NBR/Viton Gas resistant O Rings.
No drilling or modifications are needed to the gas tank. Just replace the gas cap and you're good to go! Additional gas caps, fueler, O Rings, Valves are also available separately. The "Bullet" is streamline, lightweight and fits the back of your pocket or your backpack. Fill up your gas tank and put one in your back pocket and you are ready to go!
The "Bullet Fueler" is Patent Pending.
Benefits of using this system:
1) Efficient fueling with no messy spills.
2) Quick and easy. Great for racers and bashers alike
3) Sealed Fueling. Prevents sand and mud from getting into you gas tank
4) NEVER unscrew your gas cap ever again!
5) *Drain fuel out of your Baja quickly.
6) You will always have fresh fuel in your gas tank by removing old gas from the tank.
*Great for maintaining or transporting your Baja! Your motor seals and gaskets will also last longer with an empty tank.
What's Included:
- 1 Fueler with Quick Connect Valve Switch
- 1 Billet Aluminum Quick Connect Gas Cap
- 1 Vented Aluminum/ Rubber Plug
- 1 Sealed Flushed Rubber Plug
Now Available at DDM - http://www.davesmotors.com/s.nl/c.88...egory.91830/.f
TGN - http://www.tgndistributing.com/bullet-fueler.html
Official Website: http://www.krakenrc.com
What's Included:
+ YouTube Video | |
+ YouTube Video | |
+ YouTube Video | |
+ YouTube Video | |
