fantom carby settings.
Old 08-22-2004, 01:15 AM
Team-RTR's Avatar
Default fantom carby settings.
hi, does anyone know what the factory settings are on the Fantom FR12 Rear Exhaust motor?
Team-RTR is offline
Old 08-22-2004, 08:49 PM
SlobbaTech's Avatar
Not sure what factory settings are but if put the main needle at 2.5 turns and bottom at 1 turn + 1 hour out from closed for rotary carb, then think 1.5 turns out for slide carb turns out from closed should fire right up and be real close.
SlobbaTech is offline
Old 08-22-2004, 11:41 PM
Team-RTR's Avatar
i just rebuilt my motor and im wondering what settings i should run the needles at for break in
Team-RTR is offline
Old 08-23-2004, 10:31 AM
SlobbaTech's Avatar
Whenever I break a motor in I just keep the bottom needle same as "race tune" then the main needle is same or only 1/8" richer than when tuned right. I just don't drive the engine that hard keeping rpm down until loosens up some during break in, once loosened up and have solid polished ring top of the sleeve then good to go.
