break in bench
Old 04-11-2009, 11:33 PM
Suspended
Default break in bench
What is better to break in a motor,a break in bench or in the car?
kyosho player is offline
Old 04-12-2009, 11:49 PM
German Muscle's Avatar
if your doing high volume and need less hassle then a breakin bench, in the car is much better and quicker though.
German Muscle is offline
Old 04-13-2009, 09:12 AM
lil-bump's Avatar
Trader Rating: 89 (100%+)
I normally get about 80% done on the bench and then tranfer the engine to the car for last two tanks.
lil-bump is offline
Old 04-13-2009, 06:25 PM
wizby's Avatar
The bench is alot easyer. And I can run it anytime I want.
wizby is offline
Old 04-16-2009, 12:49 PM
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
but, say using the murnan method, breaking in the car, will be fsater? as stated above? i would think the stand would put less strss on conrod producing logevity of parts, but if in car hampers a FASTER motor, in the car it is!!
TommyBlazin is offline
Old 04-16-2009, 01:15 PM
jakerz's Avatar
I use the bench. I heat the engine with a heat gun to 220deg, fire it up and run it a 1/4 to 1/2 throttle for a full 1/2 gallon with out stopping at 220deg (i made a custom 1/2 gallon fuel cell). This establishes a perfect piston sleeve match. Then I put it in the car and start to lean it out and run it. I have never had engines "come to life" as much as they do with other methods compared to this method.
jakerz is offline
Old 04-16-2009, 01:17 PM
Roelof's Avatar
The run-in methode can not say how the engine will be. Most populair methodes are based on the same principle: rich and full throttle. Because the tolerances no engine is the same and results the same with the same run-in methode.
Just use what you think is the best and you will be satisfied.
Roelof is offline
Old 06-19-2009, 07:49 PM
jt415gz's Avatar
Don't you want to heat cycle it at all in between tanks?
I just read this and it sounds dangerous haha, but is it okay for the piston/sleeve/conrod/wristpin?
I read L. Collari uses this method..........but ya' know...engines to these top drivers are a penny a bag.
http://www.cefx.net/tips/nitro/break-in/index.php
jt415gz is offline
Old 06-26-2009, 01:12 AM
jt415gz's Avatar
dead thread but anyway
no use for an air filter on the Hudy Break-in Bench? From the looks of the bench it doesn't look like it will fit an air filter at all... where's the safety from debris small particles?
jt415gz is offline
Old 06-26-2009, 05:33 AM
nazwenhome's Avatar
Trader Rating: 33 (97%+)
i did 1/4 of a gallon on a breakin bench, 3 tanks on track,with 1/5-1/4 turn down on HSN each tank
nazwenhome is offline
Old 07-01-2009, 06:22 AM
lil-bump's Avatar
I snag a pair of the old lady's stockings. Cut a small portion then place it over the carb intake. Use a rubber band to secure it. douche it with a little air filter oil. Not the best but it's the only thing I have found that fits.
Pass you soon...
lil-bump is offline
Old 07-01-2009, 09:18 AM
nazwenhome's Avatar
this is interesting i wonder if this method can be use as safety precaution during play time
Old 07-01-2009, 09:59 AM
lil-bump's Avatar
I would not use this for normal running. I only use this while using a break-in bench
lil-bump is offline
